Honda PCX FAQ
Honda PCX FAQ
Honda PCX Specifications (mirrored here from Honda's Website)
ENGINE
Engine Type 125cc liquid-cooled single-cylinder four-stroke
Bore And Stroke 52.4mm x 57.9mm
Induction PGM-FI with automatic enrichment
Ignition Digital with electronic advance
Compression Ratio 11.0:1
Valve Train SOHC; two-valve
DRIVE TRAIN
Transmission Honda V-Matic belt-converter automatic transmission
CHASSIS / SUSPENSION / BRAKES
Front Suspension 31mm hydraulic fork; 3.5 inches of travel
Rear Suspension Unit swingarm, 2.9 inches of travel
Front Brake Single 220mm disc with three-piston caliper and CBS
Rear Brake Drum with CBS
Front Tire 90/90-14
Rear Tire 100/90-14
DIMENSIONS
Rake 27.0 degrees
Trail 86mm (3.4 inches)
Wheelbase 51.4 inches
Seat Height 29.9 inches
Curb Weight 280 pounds (Includes all standard equipment, required fluids and a full tank of fuel-ready to ride)
Fuel Capacity 1.6 gallons
Miles Per Gallon 110 mpg*
OTHER
Model Id PCX125
Available Colors Pearl White, Candy Red (USA) Black Nighthawk, Silver Metallic, Gold Metallic (International)
Emissions Meets current EPA standards.
FACTORY WARRANTY INFORMATION
One Year Transferable, unlimited-mileage limited warranty; extended coverage available with a Honda Protection Plan.
Note *Honda's fuel economy estimates are based on EPA exhaust emission measurement test procedures and are intended for comparison purposes only. Your actual mileage will vary depending on how you ride, how you maintain your vehicle, weather, road conditions, tire pressure, installation of accessories, cargo, rider and passenger weight, and other factors.
MSRP $3,299
General Questions
-> What is the top speed of the Honda PCX?
Most US Spec PCXs attain a top speed around 60mph. International models seem to have a slightly higher top speed, around 62-65mph.
-> What actual mpg do you get?
It varies with driver riding style, but in practice, most riders get between 90 and 100mpg (US gallons). Source here. Fuel mileage drops off steeply if the scooter is ridden at maximum speed. The most economical speed is around 40mph.
-> Should I winterize my scooter?
If you are not going to ride your scooter for more than a month, it should be winterized. See here for instructions.
