honda pcx125 coolant
Mike888
Color: Gray pcx150
Post by Mike888 »
I have a question regarding coolant on my honda pcx125. I haven't changed my coolant and the scooter has only 1000miles. I wanted to know since the original color of my coolant is green and the one i bought from honda is blue, should i buy two bottle. The first bottle is to rinse out the green coolant and the second is to fill it up to make sure the blue and green don't mix. Also i noticed in the manual it says to snap the throttle 3-4 times to bleed out air bubbles. What does that mean. Does it mean to rev it 3-4 times. Also when done finishing filling up the coolant should i turn on the engine and check to see if the level off coolant goes down and then top off and put the radiator cap back on. Thank you for your help
Re: honda pcx125 coolant
Mike888 wrote:I have a question regarding coolant on my honda pcx125. I haven't changed my coolant and the scooter has only 1000miles. I wanted to know since the original color of my coolant is green and the one i bought from honda is blue, should i buy two bottle. The first bottle is to rinse out the green coolant and the second is to fill it up to make sure the blue and green don't mix. Also i noticed in the manual it says to snap the throttle 3-4 times to bleed out air bubbles. What does that mean. Does it mean to rev it 3-4 times. Also when done finishing filling up the coolant should i turn on the engine and check to see if the level off coolant goes down and then top off and put the radiator cap back on. Thank you for your help
Leave it in. Worry about it after 20k if you must.
By that time you'll have sold the bike or totalled it.
That hasn't helped has it? Of you go....
