Switch for Tank/Seat not working
McGee
Post by McGee »
I had my Forza shipped and now while fixing a new Battery I discovered that the Switch to open Tank and Seat is not working.
If I am correct did the Switch move nearly a cm up and down before whereas now its just 2 or 3 mm.
I assume that either Customs or Forwarder managed to break something.
Question: is it an electrical or mechanical switch?
Any Suggestion how to fix it?
I cant even drive it to the Dealership as the Forwarder emptied the Tank completely prior to shipping.
Thank you in advance for suggestions
>> Marriage is a wonderful invention: then again, so is a bike repair kit. <<
BRed
Year: 2023 XMax 300
Color: Grey and black
Re: Switch for Tank/Seat not working
Post by BRed »
The tank access flap, left glove box and seat releases are mechanical (cable) in nature but they are locked/unlocked by the ignition switch. The interlock on the key switch is also mechanical and simply blocks movement of the mechanical latches when the key is off.
davenowherejones
Post by davenowherejones »
Jiggle the key??? Jiggle the front wheel? Both at the same time???
McGee
Post by McGee »
JIGGLING THE KEY !!!!!
who would have thought of that !!
Thank you, thank you, thank you !!
That made my day.
intermittent pressure of the Switch by jiggling the Key did the Job.
