self healing tires...
I don't want the added weight of this product nor do I care to imagine it will stay balanced but still a very interesting concept and hard to watch
- honkerman
Re: self healing tires...
We discussed these a bit at school. There are certain...issues with run flat tires on a motorbike. Run flat tires have a hard feel to begin with, which would seem problematic on a bike. Yes, you need firmness in a tire, but there are limits. Then there is the likely cost.
- waspmike
Just bung a bottle of Slime into the tire. If you walk out and there is green stuff all over, you have a flat. If it tries to deflate when riding it will be slower and you have a chance to stop.
Other than a need to sell tyres, I wondered why you couldn't get tyres that are non hollow i.e. spongy bee-hive rubber pockets inside the tyre so reduced weight but so with so many individual pockets, it would not go flat just a small puncture on a cm hollow pocket. It seems there may be other reasons manufacturers do not sell these? I guess the tyre would wear and need replacing so perhaps not worth the extra cost.
I use balance beads in the tires and need to keep that in mind when adding any puncture sealing products. I bet there are some of you that need this stuff but for my area I've been lucky for years concerning flats on any vehicle.waspmike wrote:Just bung a bottle of Slime into the tire. If you walk out and there is green stuff all over, you have a flat. If it tries to deflate when riding it will be slower and you have a chance to stop.
- honkerman
Interesting to note, during the tire change segment at school, we discussed plugs and while some of the instructors have used them for their personal bikes, they didnt recommend it in motorcycle tires. I can't remember all the reasons why, and I think on a scooter tire with less likelihood of high speeds, it would not be so bad, because plugging a tire drops its speed rating, which we're not even close to on a PCX. Some also suggest that a plug should only be used for rear tires, never for fronts, and that makes sense.homie wrote:I use balance beads in the tires and need to keep that in mind when adding any puncture sealing products. I bet there are some of you that need this stuff but for my area I've been lucky for years concerning flats on any vehicle.waspmike wrote:Just bung a bottle of Slime into the tire. If you walk out and there is green stuff all over, you have a flat. If it tries to deflate when riding it will be slower and you have a chance to stop.
I've been using Ride-On in my tires since I posted about it here in 2011, first on the PCX and now on the Forza. Works great, eliminates the need for wheel weights or balance beads. One application lasts the life of the tire. Never lose air pressure in my tires.
Post subject: Re: Tire Sealant?PostPosted: Sun Nov 20, 2011 9:12 pm
Here is the products description and promiseAustinPCX wrote:I've been using Ride-On in my tires since I posted about it here in 2011, first on the PCX and now on the Forza. Works great, eliminates the need for wheel weights or balance beads.
http://www.ride-on.com/motorcycle-formula-mot.html
Haven't heard of this before and thanks for the information. Too late for me as I said I put quality balance beads already but it would have been nice. To the benefit of this product I can hear the beads 'swish' when I roll the wheels which this product would not do that. The 'swish' is harmless unless you don't recognize what it is on a used bike purchase, thus sending you on a hunt for the sound. Baffled me for a moment but when you hear the beads settling in after the roll of the wheel has stopped... you get a clue
homie wrote:Here is the products description and promiseAustinPCX wrote:I've been using Ride-On in my tires since I posted about it here in 2011, first on the PCX and now on the Forza. Works great, eliminates the need for wheel weights or balance beads.
Just say snake oil to any potential purchaser and I'm sure they'll be fine.
