Hi.
The OM states that the oil should be changed every two years - Nothing else !
The only posts I can find relate to changing the final drive oil is in respect of a PCX.
Can anyone please guide me through or refer me to an existing post on how to change the final drive oil on my Forza NSS300 including the type and quantity of oil that should be used and finally the drain and fill bolt torque settings.
Thanks.
Final drive oil - NSS300
dergav
- Color: grey
Re: Final drive oil - NSS300
I dont think i can post attachments or I could post a pic copy of the final drive page from the service manual copy I have ( USA version...but assume for most maintenance /service matters it will be same as in UK etc) )...however it looks simple enough..
says
Oil...viscosity:SAE 10W-30
check bolt Torque..13N-m
filler bolt Torque..13N-m
new sealer washers recommended for each bolt
remove the oil check bolt ( lower of the two bolts) and washer...
remove the oil filler bolt and washer...then slowly turn the wheel and drain the oil
After oil has completely drained install the drain bolt with new washer and pour in the recommended oil through the oil filler hole.
Oil capacity...0.28Ltr ( after draining)....0.30Ltr ( after disassembly.)
If I knew your email address I could copy over the relevant page.
Hope this helps...others may be able to post pics.
says
Just found this on the net: http://www.49ccscoot.com/manuals/2001-2 ... Manual.pdf
dergav
- Color: grey
That is a useful find...albeit not exactly for the Forza NSS300...having had a look and compared as best as I can to the manual for the NSS300 it looks very similar ( not surprising)...Torques the same ... oil quantities differ.
Jockay
- Year: 2019 Forza 300
- Color: Blue
Thanks for the information and your offer dergav.
I would have liked to send you my email address, by PM, but it seems that I am not authorised to send messages yet however it looks as though I can receive them - Perhaps you would be good enough to PM me your EMA and I will then reply.
Thanks very much for the feedback in general.
