It won't start!
Tnoodler
It won't start!
Post by Tnoodler »
Attempting to start scooter, all dash lights come on (not the engine light) and seems normal. All switchology correct, nothing, does not make a peep. Never happened before.
-Yes, side stand is up.
-It is not the battery. Charged just fine with battery tender, and I even swapped another battery in.
-Checked fuses in the tiny "fuse box" in the battery compartment. All seem fine.
-Has been running just fine, I do hose the bikes down twice a week since I am next to ocean.
Is it possible the side stand switch is busted? I tried to view it but I don't understand how it works, I mean I couldn't get a good angle to view it. Any ideas? Appreciate any input that might save me from a painful trip down to the scooter store!
Re: It won't start!
Pulling the left brake lever hard enough?
Tnoodler
Re: It won't start!
Post by Tnoodler »
Yes, read some other no-start posts and tried that. Although we have owned this for months with no issues. Tried cycling the side stand a few times while trying to start thinking it might be sticking but still nothing. No clicking or anything. I am wondering if I shorted something by hosing it off.
Re: It won't start!
Does the fuel pump kick in to get fuek into the system when you turn on the ignition? That said, if you do not hear anything, total silence when starting then it's something else. No flashing lights on the dash to indicate a fault?
Tnoodler
Re: It won't start!
Post by Tnoodler »
No, no flashing lights and absolutely no noise when I press start button. I do notice that the engine light does not even momentarily come on like the manual says it should momentarily. Are there other fuses besides those in the fuse box that you know of? Thank you.
pcx man
Re: It won't start!
Post by pcx man »
Put the bike on the center stand and see if the rear wheel turns freely. I remember a case where the belt & variator jammed and would not let the engine turn. Try to start it on the center stand. Also check to see if the brake light works with left and right brake lever. It maybe that it will not start if the bulb is bad.
Tnoodler
Re: It won't start!
Post by Tnoodler »
Rear wheel spins freely with only a slight bit of friction but seems normal. Both brake levers are working and bulbs ok. I notice headlamp does not come on, but don't recall if that comes on prior to engine start?
Re: It won't start!
Tnoodler wrote:Rear wheel spins freely with only a slight bit of friction but seems normal. Both brake levers are working and bulbs ok. I notice headlamp does not come on, but don't recall if that comes on prior to engine start?
Flat battery?
dkazzed
Year: N/A
Re: It won't start!
Post by dkazzed »
you you wrote:Flat battery?
What would flatten the battery? An elephant stepping on it? Wouldn't that wreck the rest of the scooter?
2015 Honda CB300F ABS
Re: It won't start!
Not if the mahout gets the battery out first.
Re: It won't start!
The start system is relatively straight forward. If you are certain beyond a doubt that the battery is good, then make sure the side stand switch is still good. (I would say that a full 90% of the start problems are because of the battery or the side stand switch.) You might be able to bypass it with some small jumper wires. Also, the main fuse 1 and fuse 2 are both in that circuit. So is the relay which is Starter/Charging Relay, which is above the battery. Before you start digging into everything though, I would first get a can of air and blow the switches on the brake handles to make sure the contacts are working correctly. Then flip the Start switch back and forth while the key is in the ON position. If you hear the fuel pump cycle you will know that part is good. Do all of the testing with the bike on its center stand and the side stand up. That will give you fewer things that you might forget. Once you get past those we can revisit this problem. I have a shop manual and there is a whole section on stater problems.
Re: It won't start!
Does the engine light come on or not? You seem to contradict yourself.
When the ignition is swiitched on do the indicators and brake lights work?
Re: It won't start!
It's a lead acid accumulator if you really want to try at this sort of thing. Over to you now as I'm not going to get involved in a battle of wits with an unarmed opponent.
GeeGusKahn
Re: It won't start!
Post by GeeGusKahn »
Have you checked the kill switch ??
Re: It won't start!
PCX Starter Circuit.jpg (193.23 KiB) Viewed 28526 times
I hope this helps you. It is the electrical starter circuit.
Re: It won't start!
The 1st post suggested a 2nd battery was tried so it can't be a flat battery (as the other was trickle charged anyway). Is the kill switch just on certain models? Don't even know where mine would be, if it's fitted. Also surprised to see the diagram suggest either brake can be pulled in to start the bike - always thought it was only the left one (rear).
Tnoodler
Re: It won't start!
Post by Tnoodler »
Of course my buddy shows up with his truck and the thing starts fine. I believe is was a short in the kill switch--maybe a case of water intrusion. I noticed when moving the key to start position, with the kill switch in the "kill" position, I got the same indications as when the scooter was failing to start. Played with the side stand after it was running and the side stand switch did its job perfectly.
Appreciate all the recommendations, and thanks for the diagram MeI46!
Re: It won't start!
Kill switch only fitted to north american model in place of the idle stop switch.
waspmike
Re: It won't start!
Post by waspmike »
You might be from British Columbia if:
1. You know the provincial flower (Mildew)
2. You feel guilty throwing aluminum cans or paper in the trash.
3. Use the statement "sunny break" and know what it means.
4. You know more than 10 ways to order coffee.
5. You know more people who own boats than air conditioners.
6. You feel overdressed wearing a suit to a nice restaurant.
7. You stand on a deserted corner in the rain waiting for the "Walk" signal.
8. You consider that if it has no snow, it is not a real mountain.
9. You can taste the difference between Starbucks, Blendz, and Tim Horton's.
10. You know the difference between Chinook, Coho, and Sockeye salmon.
11. You know how to pronounce Squamish, Osoyoos & Nanaimo.
12. You consider swimming an indoor sport.
13. You can tell the difference between Japanese, Chinese, Vietnamese, Korean and Thai food.
14. In winter, you go to work in the dark and come home in the dark -while only working eight-hour days.
15. You never go camping without waterproof matches and a poncho.
16. You are not fazed by "Today's forecast: showers followed by rain," and
Tomorrow's forecast: rain followed by showers."
17. You cannot wait for a day with "showers and sunny breaks".
18. You have no concept of humidity without precipitation.
19. You know that Dawson Creek is a town, not a TV show.
20. You can point to at least two ski mountains, even if you cannot see through the cloud cover.
21. You notice "the mountain is out" when it is a pretty day and you can actually see it.
22. You put on your shorts when the temperature gets above 5, but still wear your hiking boots and parka.
23. You switch to your sandals when it gets about 10, but keep the socks on.
24. You have actually used your mountain bike on a mountain.
25. You think people who use umbrellas are either wimps or tourists.
26. You recognize the background shots in your favourite movies & TV shows.
27. You buy new sunglasses every year, because you can't find the old ones after such a long time.
28. You measure distance in hours.
29. You often switch from "heat" to "a/c" in your car in the same day.
30. You use a down comforter in the summer.
31. You carry jumper cables in your car and your wife knows how to use them.
32. You design your kid's Halloween costume to fit under a raincoat.
33. You know all the important seasons: Almost Winter, Winter, Still Raining (Spring), Road Construction (Summer) & Raining Again (Fall).
34. You actually understand these jokes!
Edit: 35. You know where the Peoples Republic of Richmond is.
36. Image
:lol:
mhrunge
Re: It won't start!
Post by mhrunge »
Just had this very same issue, after investigating, was found to be a dirty fuse, replaced all while I was at it and the bike runs great now. 2011 PCX Thai made with 47k KM...
