Adding Lights
Adding Lights
Hi I am in the UK and thinking of getting a PCX and once getting it adding additional lights to front and rear so I can have flashing Amber warning lights front and rear but still have incidators it will be on a 2015 model. Any advice on the best place to mont they are small hideaways about 1 1/2" diameter.
Thanks
Thanks
Re: Adding Lights
You will need to check the regulations there before adding any flashing lights to your bike. We have a light in the rear of ours that goes back and forth while we are riding, then flashes when we hit the brake before going on steady. Your country may now allow that though, so make sure before doing anything. Check the front light requirements too. Additional driving lights may or may not be allowed.
Re: Adding Lights
Yes I allowed Amber flashing just not blue, green and red flashing lightsMel46 wrote:You will need to check the regulations there before adding any flashing lights to your bike. We have a light in the rear of ours that goes back and forth while we are riding, then flashes when we hit the brake before going on steady. Your country may now allow that though, so make sure before doing anything. Check the front light requirements too. Additional driving lights may or may not be allowed.
Thanks
Response5
Voluntary First Aider in the UK
Response5
Re: Adding Lights
Response5 wrote:Yes I allowed Amber flashing just not blue, green and red flashing lightsMel46 wrote:You will need to check the regulations there before adding any flashing lights to your bike. We have a light in the rear of ours that goes back and forth while we are riding, then flashes when we hit the brake before going on steady. Your country may now allow that though, so make sure before doing anything. Check the front light requirements too. Additional driving lights may or may not be allowed.
Our Xmas tree would be arrested....
Re: Adding Lights
I was looking at this in Amber but need help of where I can put it
http://responsevehiclelighting.co.uk/pr ... nt_image=3
Thanks
Response5
Response5
- Year: 18 300 xmax
Re: Adding Lights
See my build thread for front and rear added lights.
‘15 PCX build thread here:
Re: Adding Lights
No you are not - even off-colour indicators that are too far from amber are strictly an MOT failure.Response5 wrote:Yes I allowed Amber flashing just not blue, green and red flashing lightsMel46 wrote:You will need to check the regulations there before adding any flashing lights to your bike. We have a light in the rear of ours that goes back and forth while we are riding, then flashes when we hit the brake before going on steady. Your country may now allow that though, so make sure before doing anything. Check the front light requirements too. Additional driving lights may or may not be allowed.
You can only have a steady white light to the front and a steady red light showing to the rear of your vehicle. The exceptions to this are: BLUE flashing from an emergency vehicle or flashing or constant from a police vehicle
Members of the public may not have blue flashing lights, regardless of whether they are connected, at all!
Several headlights these days have a blue ting, but the law states the primary colour must be white - hence those HID style EU lights that are common place. Flashing amber is only allowed for indicators, not running lights or brake lights - that is why it is illegal to be moving with hazard lights (both indicators flashing) if your vehicle is not broken down.
Re: Adding Lights
I would be using Amber for when going through road closures (when permitted/ told to) and when broken down or assisting a broken down vehicle as I was doing the other dayiceman wrote:No you are not - even off-colour indicators that are too far from amber are strictly an MOT failure.Response5 wrote:Yes I allowed Amber flashing just not blue, green and red flashing lightsMel46 wrote:You will need to check the regulations there before adding any flashing lights to your bike. We have a light in the rear of ours that goes back and forth while we are riding, then flashes when we hit the brake before going on steady. Your country may now allow that though, so make sure before doing anything. Check the front light requirements too. Additional driving lights may or may not be allowed.
Thanks
Response5
Response5
Re: Adding Lights
Well, your '15-'16 PCX has hazard lights as standard, so why add more for the rare occasion you may brake down or assist other people.
Re: Adding Lights
iceman wrote:Well, your '15-'16 PCX has hazard lights as standard, so why add more for the rare occasion you may brake down or assist other people.
Did cross my mind too..
Re: Adding Lights
More to add visability to them so I can been seen further awayyou you wrote:iceman wrote:Well, your '15-'16 PCX has hazard lights as standard, so why add more for the rare occasion you may brake down or assist other people.
Thanks
Response5
Response5
- Oyabun
- Year: `12,`15,`19
- Color: black&black
Re: Adding Lights
I'd consider to add led strips. I remember to see both white-amber and red-amber ones which can couple as additional position lights for increased visibility just like the ones on newer Audi and VW cars.
Re: Adding Lights
Sounds good I will look into itOyabun wrote:I'd consider to add led strips. I remember to see both white-amber and red-amber ones which can couple as additional position lights for increased visibility just like the ones on newer Audi and VW cars.
Thanks
Response5
Response5
Re: Adding Lights
Response5 wrote:More to add visability to them so I can been seen further awayyou you wrote:iceman wrote:Well, your '15-'16 PCX has hazard lights as standard, so why add more for the rare occasion you may brake down or assist other people.
Fair enough. I'd just use LEDs and wire into the hazards then?
