Hello.
I purchased this Honda Vision 110 a few months ago. There is a problem with the head bearing I think?
Please see the below link:
https://youtu.be/fJTJlKeicSE
As you can see, the handle bars are turned full lock to the right, but when I lift the front end of the bike the bars fall all the way from the right lock to the left… I suspect that the head bearings are damaged (was a delivery bike before and I don't think it was looked after).
The front is wobbly when riding and I have to lean to the right as the bike pulls to the left.
I tried to tighten up the head bearing adjuster nut and this got rid of the front end wobble for a while (this did not eliminate the bike pulling to the left though) but now it has come back! I think that now the head bearing has been tightened, the bike is also now slow to reach and it feels worse than before.
What should I do please!!
Thanks
Sean
Honda vision head bearing damage??
seanyp83
- Color: blue honda visi
Re: Honda vision head bearing damage??
Sorry.
I have made the video public now and you should be able to view it.
Thanks
Thanks
The problem isn't solely the head bearing, looks to me like the forks, yoke, or frame are bent.
seanyp83
Really?!
Arrr man!!!!
I've taken it to 2 motorcycle mechanics in hackney London and the both fobbed me off.
Any know of a good bike mechanic in the hackney/east or north London area please?
OR could I tackle this myself? I have an old Haynes manual for a Honda ps and can see how to change the bearing.
Sent from my HTC
Arrr man!!!!
Sent from my HTC
Have you checked that there aren't any tight or mis-routed cables which are pulling on the steering?
If that isn't it the steering's utterly fooked.
seanyp83
Good point!!
I can see that the speed cable looks little short. I will have to check the brake cable also.
When I turn the bars to the right full lock can feel some sort of resistance (like a tensed cable).
I'll double check.
Thank you :-)
I'll double check.
Thank you :-)
Mister Paul
Why not take it to a Honda dealer for assessment? It could be nothing or everything.
Sell it scrap it and move on.....seanyp83 wrote:Hello.
Thanks
Sean
