Hi folks,
Recently had work done by dealer and just noticed a gap between headlight and offside fairing.
Haven't really got the time to take it back if its something I can remedy. I've tried a bit of pressure to see if it'll pop back but no go. Anyone able to advise how I can gain access to the innards and any tips please?
Thanks.
headlight/fairing question
Smee
- Headlight.jpg (459.25 KiB) Viewed 1983 times
Re: headlight/fairing question
Smee wrote:Hi folks,
Thanks.
Take it back to the dealer?
- ONTWOWHEELS
- Color: WHITE
Take it buck to the dealer because if you push it as i recall it will brake the clip or the nest of the clip.
It must be taken off and putted back in a way down and slip to the front (i wish i said it right).
I 'm trying to say that it has a way to be put back in place.
HONDA PCX 125 /2015 - HONDA PCX 150/2016
ONTWOWHEELS wrote:Take it buck to the dealer because if you push it as i recall it will brake the clip or the nest of the clip.
Dealer that did the original work then?
- ONTWOWHEELS
- Color: WHITE
Who else ? He did not put it back in the proper way.you you wrote:ONTWOWHEELS wrote:Take it buck to the dealer because if you push it as i recall it will brake the clip or the nest of the clip.
