How do use this hole?
Posted: Fri Nov 13, 2015 7:14 pm
How do use this hole??
https://hondapcx.org/
I see, thank you very much!WhiteNoise wrote:No worries, I had the same question when I got my first PCXThat's the CBS Brake Fluid Reservoir viewing window. You can check your level by peering in (sometimes it's hard to see the level especially if the fluid is colorless or if the reservoir is full to the top). Grab a mini flashlight and jiggle the bike (carefully) if it's really full. Can you see the fluid?
Scroll down this page: http://www.hondapcx.org/viewtopic.php?f ... r&start=40
Joey6262 wrote:Quick Tip - I used a green beam flashlight and it makes the fluid level much easier to see.
Great tip. Thanks!Joey6262 wrote:Quick Tip - I used a green beam flashlight and it makes the fluid level much easier to see.
