I have purchased some performance mods for my PCX 125 esp 2014.
1/ Yuminashi high lift camshaft ESP, not the RR version, the first version, got it from a friend who bought it but never used it.
2/ New 58mm piston and PCX150/SH150 cylinder, my piston has 13 pin, which is originally a Honda Sonic 125 piston.
3/ Had my mechanic done some work on the cylinder head, I think he just enlarged the combustion chamber to fit the new 58mm piston surface, not so sure on the valve diameters, have to recheck on it, but the valve springs are the same.
4/ Modded stock exhaust. Where I live, there're shops who would mod the exhaust, so I modded it, basically take everything out and use a new core, wrapped it with some fiberglass.
My problem is this.
1/ Yuminashi has said that the first version of their camshaft needs/requires (I'm not so sure) a new set of rocker arms or I have to grind it (not too keen on grinding anything) because the cam lobe would touch the rocker in the middle. As careless as I am, I installed it without reading that first and my engine now has some sorts of ticking sound, just like Yuminashi said. Will this damage my engine? Because I commute almost everyday and having my engine's pulled out is almost impossible.
2/ Valve bounce. Like I said, my valves kinda bounce a little. Just like an old dirtbike that had one of those flat-slide carbs which rattles. But only when I whack open the throttle extremely suddenly, it rattles a little then nothing. I have read about this, my mechanic said that because the stock exhaust is too restrictive, which causes exhaust pulses to affect the valve springs. Yuminashi has a set of double valve springs. Would a set of too stiff valve springs affect the rocker arm or the camshaft in anyway? I planned to try a new exhaust header or pipe, about 32mm in diameter, or 30/28 and keep the exhaust pipe as straight as possible.
I know it's long but since I'm a noob, please forgive me.
![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
