Footrest for rear passenger on 2013 PCX
- yak
- Minister of Magic
When i swung out the footrest, something popped out and rolled away. It was a screw that holds 2 plastic parts together. The 2 plastic parts are directly beneath the footpeg. I checked the footpeg on the other side and the screw (looks a bit like a bolt) was tight. I have taped the 2 plastic parts together. Do i need to buy a replacement screw? Does it serve any purpose other than the obvious one?
- MikeP
- Color: White /red
Re: Footrest for rear passenger on 2013 PCX
The bolt simply holds the plastic parts together. Taping the plastics would work, but if it were my bike I would just buy the bolt from the dealer. It is probably only a dollar or so.
yak, was that what you wanted to know? What Mike said? Advice sounds good to me
pm sent, hope it helps
