A couple months ago it was still functioning if I duct taped it back in place and like an old set of headphones, moved the wires around a bit. Actually stayed in place at highway speeds, no light issues.
Soon as the temperature changed to cold here in Autumn, left rear flasher light no longer works.
So, I opened up the housing and inspected the light. Little bit of crust in there. Tried to remove the light but it won't budge.
Searched for answers and found no topics on it.
1) How do I remove the actual bulb. Do I just don a pair of grippy gloves and give it a yank?
2) Based on my description above, other than the bulb, what could it be that is causing the light not to function?
3) The right side is fine. The left indicator on my dash comes on solid but no flash. Left rear light itself does not come on.
