Tyre Choice
Toonman
Tyre Choice
I've been given the choice of Dunlop scootsmart or Michelin city grips tyres.
Does anyone have any experience of either of these? And what would be the best option?
Re: Tyre Choice
Oh boy, oh boy, oh boy that's a very familiar question
Folks seem to favor City Grips, but
there are many tire discussions on the forums, so I'm thinking it's best if you use the search bar and type in City Grip tires (as an example).
Don't go away, I'm betting others will kick in soon
Re: Tyre Choice
Whichever is cheapest.Toonman wrote:what would be the best option?
They're both good tyres.
- ScooteringAbout
Re: Tyre Choice
I use CityGrips however 4,500miles in the rear is tram-lining, so make your own mind up from that.
aka DrewJW
Toonman
Re: Tyre Choice
Cheers gents.
buddy1976
Re: Tyre Choice
used both, choose city grips you wont regret it.
Honda forza 125 2019
Yellow malossi contra spring
Malossi delta clutch and bell
Malossi special kevlar belt
K and n air filter
Akrapovic exhaust
Malossi White Contra Spring
Malossi yellow clutch springs
Daytona reinforced belt
DNA Performance air filter
Removed air box flange
Removed seat hump
Ermax+25 windshield
K and n air filter
Akrapovic exhaust
Removed seat hump
Ermax+25 windshield
Re: Tyre Choice
Someone posted an alternative make that gets great reviews and is cheaper than the City Grips (and seems to have better grip too). Heidenau K66 - no idea on longevity or real world performance, but seems worth considering.
Re: Tyre Choice
iceman wrote:Someone posted an alternative make that gets great reviews and is cheaper than the City Grips (and seems to have better grip too). Heidenau K66 - no idea on longevity or real world performance, but seems worth considering.
Fantastically helpful, thanks.
Re: Tyre Choice
More helpful than your typical piss-take response. I know there were initially two choices, just mentioning an alternative to consider that the op may be able to get fitted.you you wrote:Fantastically helpful, thanks.iceman wrote:Someone posted an alternative make that gets great reviews and is cheaper than the City Grips (and seems to have better grip too). Heidenau K66 - no idea on longevity or real world performance, but seems worth considering.
Mister Paul
Re: Tyre Choice
Scootsmart. £42 delivered from mytyres.
- easyrider
- Color: blk
Re: Tyre Choice
I don't think they come in specified size Honda recommends 90/90-14 or 100/90-14iceman wrote:Someone posted an alternative make that gets great reviews and is cheaper than the City Grips (and seems to have better grip too). Heidenau K66 - no idea on longevity or real world performance, but seems worth considering.
- Oyabun
- Year: `12,`15,`19
- Color: black&black
Re: Tyre Choice
I run Heidenau K66 tires both front and rear. Had been using them in -5 to 25 degC sun rain, damp and ice. Dunno where you live but I could not recommend it more. I run 110/80 at the front and 120/80 at the rear.easyrider wrote:I don't think they come in specified size Honda recommends 90/90-14 or 100/90-14iceman wrote:Someone posted an alternative make that gets great reviews and is cheaper than the City Grips (and seems to have better grip too). Heidenau K66 - no idea on longevity or real world performance, but seems worth considering.
The front needed some shaving of the side hairs of the tire but the rear was a perfect fit. The slightly taller and wider rubber is doing real good when it comes to damping and cornering. Each end with the new rubber is slightly heavier than my worn originals were.
Hope this helps.
- honkerman
Re: Tyre Choice
They do not seem to be available here in the states. Too bad reallyOyabun wrote:I run Heidenau K66 tires both front and rear. Had been using them in -5 to 25 degC sun rain, damp and ice. Dunno where you live but I could not recommend it more. I run 110/80 at the front and 120/80 at the rear.easyrider wrote:I don't think they come in specified size Honda recommends 90/90-14 or 100/90-14iceman wrote:Someone posted an alternative make that gets great reviews and is cheaper than the City Grips (and seems to have better grip too). Heidenau K66 - no idea on longevity or real world performance, but seems worth considering.
Hope this helps.
Re: Tyre Choice
If worried about top speed don't forget outer diameter. Don't put on new tires then complain you have lost 2-3 mph!
- Oyabun
- Year: `12,`15,`19
Re: Tyre Choice
Actually my real gps measured top speed has not changed at all if not increased a hair. The speedo indicated figure got lower by 2 km/h practically meaning it became slightly less over optimistic. Nothing I'd e worried about.
zanggerk
- Year: 2012
Re: Tyre Choice
Actually they do:easyrider wrote:I don't think they come in specified size Honda recommends 90/90-14 or 100/90-14iceman wrote:Someone posted an alternative make that gets great reviews and is cheaper than the City Grips (and seems to have better grip too). Heidenau K66 - no idea on longevity or real world performance, but seems worth considering.
http://en.reifenwerk-heidenau.com/modul ... =58&pic=60
zanggerk
- Year: 2012
Re: Tyre Choice
As I just found out, Heidenau tires are distributed also in the US, but obviously the K66 not in the official PCX size.
http://heidenautires.com/scooter-street-tires/
Re: Tyre Choice
OK just that there is a 2-3 mph difference between City Grips and IRC. If one cannot get IRC then it doesn't matter. If the bike didn't come with IRC then it probably also doesn't matter.Oyabun wrote:Actually my real gps measured top speed has not changed at all if not increased a hair. The speedo indicated figure got lower by 2 km/h practically meaning it became slightly less over optimistic. Nothing I'd e worried about.
Re: Tyre Choice
Why the mph difference? I can understand that tyres that grip more (and the jury on those two tyres is in favour of CG's but not %100), but why the 3mph less? Is the diameter of the two slightly different?
