Will a 15 head light assembly fit in a 13 pcx150?
Osseopowersports
Post by Osseopowersports »
I have a customer who has had an accedent with his 13 PCX 150. His front head light assembly is smashed and I was thinking it would be nice to let him know if the 15 light assembly with the LED's would work. Thanks for your help.
Oyabun
Year: `12,`15,`19
Color: black&black
Re: Will a 15 head light assembly fit in a 13 pcx150?
Post by Oyabun »
To have a quick answer, not possible without major panel and I assume mounting modifications (this later I'm not sure, but the headlights have different shape.
I advise to look for posts from a fellow forum member called Dasshreddar.
He builds a rebuilds a frankenstein PCX based on a 2010 or 2012 model, which at one point had a LED headlight assembly installed. He noted that it was a major issue to mount and then the LEDs burned out as he had not used a proper driver for them.
Osseopowersports wrote:I have a customer who has had an accedent with his 13 PCX 150. His front head light assembly is smashed and I was thinking it would be nice to let him know if the 15 light assembly with the LED's would work. Thanks for your help.
No. It's clearly a different shape and size
Osseopowersports
I printed the schematics of both light assemblies and I see now that they are clearly different. Plus wire harness would have to be modified...
