i have a 2013 PCX, i noticed the turn signal assembly is in 2 pcs, but the parts show it as one pc, it is separating at the seam between the hard plastic and rubber i tried to push it back in place but wont stay, i tried taking it apart but cant seem to see what holds the 2 sections together, any suggestions
Chet
turn signal housing
- Color: red
Re: turn signal housing
The light housing itself is a lens, gasket and rear shell with two screws holding it together. Are you maybe seeing the gasket sticking out between the halves? If so, undo the halves and re-install the gasket carefully. Sometimes the gasket might be severely deformed and need replacement. If none of this, than may I see a picture of the condition? Looks pretty straight-forward in the book.
