Question on center grab handdle cover removal.
Gnarg
Can any of you Forza guys who have removed the center grab handle cover to drill the holes for a carrier bracket installation tell me the proper way to remove those two balck pins or caps, (not sure what they are?) located under the seat which need to be removed in order to remove the center cover? Finely getting around to installing my Givi Bracket for the Top case. I searched the forum before posting this question and theres a lot of good info on installing the Givi bracket and top cases but nothing i can find specifically on what type of pins or srews they are and how to go about removing them so u dont break something or end of scratching the finish. I hope i have given enough info on what they are and their location. They are two black pins or maybe screw covers which are flat on top just behind the center grab handdle cover underneath the seat.
Re: Question on center grab handdle cover removal.
Press center of pin in with pencil/pen/phillips screwdriver tip. Then lift out whole pin with fingernails or.butter knife. To reinstall whole pin first lift center up ....insert pin, push down center to flush...this locks pin in place again.
There are youtubes, and google videos I think on working with these rascals.
Mister Paul
It tells you what to do in the manual if you have one.
Gnarg
It was pretty simple. Just like Fish described.
