Oil
Oil
I would like to know if anyone knows why "energy conserving" oil is not recommended for use in the PCX150. New member. Old rider. I love my PCX. And prefer it for my semi-daily jaunts to my Kawasaki ZZR600. Just hop on and go. Looking forward to using this forum. I've had the scoot for a year now and never get tired of it.
- relic
- Color: red white
Re: Oil
seems like a honda catch 22
I think any high mileage oil will bypass the energy conserving stuff
these bikes are made to be bullet proof no mater what market they are sold in
friction modifiers in energy conserving are no good for wet clutches in most bikes
PCX's don't have clutches
same as fuel
these bikes are made to run regular why would anyone run anything more expensive
run regular fuel and high mileage oil
my 2 cents
same as fuel
my 2 cents
- Year: 26 adv 160
Re: Oil
Ill just choose an oil per the manual specs, prob 10-40 M1, and change it often. Its gotta be the easiest drain ive seen at a quart total , and no filter. So ill get a 5qt jug from amazon and change it every 3-5 months. I dont mind that sched at all. Bike used year round every day.
Re: Oil
Totally agree.Jge64 wrote:Ill just choose an oil per the manual specs, prob 10-40 M1, and change it often. Its gotta be the easiest drain ive seen at a quart total , and no filter. So ill get a 5qt jug from amazon and change it every 3-5 months. I dont mind that sched at all. Bike used year round every day.
I'm not quick to suspect the motives of motor manufacturers..
Re: Oil
Except you cannot by oil to the manufacturers specs in the UK - or so it seems. It states 10w30 MB non energy saving, but unless you import it from the US/Thailand you can't get that! (MB) Instead any good 4 stroke 10w30, 5w30 or 10w40 or such will be fine - ester, non ester, doesn't matter a jot for dry clutch honda or wet clutch bikes (most site, forums, and manufacturers responses say it's an urbann myth and bad cluthes to start with).
Some people say additives are bad for scooters as it wears seals - but that was true many years ago before technology moved on or some very poor quality China oils.
Re: Oil
Found this mini-thread trawling the net : http://www.nc700.co.uk/index.php?/topic ... -30/page-2
Interesting w50 is advised unless for consistently hot countries as it would be like treacle in normal temps)
It seems Honda spec 10w30 in the main over 10w40 for the slightly thinner hot-temp viscosity and perhaps slightly >mpg figure as w40 is thicker. That said, xxw40 is the most common fully synth oil these days.
Re: Oil
iceman wrote:Found this mini-thread trawling the net : http://www.nc700.co.uk/index.php?/topic ... -30/page-2
Yes so true and, well, whatever really
