Good to see that all those childhood days watching Blue Peter didn't go to waste !!!
DIY Underseat Luggage Tidy
mwb355
- Color: red
Came up with a quick and easy solution to all those small items that can be scattered all around your underseat storage. Using velcro straps, I made a very cheap small luggage tidy that can be fitted in minutes !
- pcxforum2.jpg (387.85 KiB) Viewed 1609 times
- pcxforum1.jpg (393.66 KiB) Viewed 1609 times
Re: DIY Underseat Luggage Tidy
Neat idea. I never put anything up there because it always ends up flopping forwards into the main area. Did you make or buy the cargo net? I've never seen one that small before.
mwb355
- Color: red
Thanks, it's just one of those luggage nets that are used to secure items to a seat. All I did was remove the 4 plastic hooks.maddiedog wrote:Neat idea. I never put anything up there because it always ends up flopping forwards into the main area. Did you make or buy the cargo net? I've never seen one that small before.
How are those straps attached that are holding the net? If it is just stick on velcro, it gets hot enough where I live that the glue lets go.
Mel46 wrote:How are those straps attached that are holding the net? If it is just stick on velcro, it gets hot enough where I live that the glue lets go.
Show off. 30 celsuis it should be here tomorrow
When Im at work
mwb355
- Color: red
Hi Mel !Mel46 wrote:How are those straps attached that are holding the net? If it is just stick on velcro, it gets hot enough where I live that the glue lets go.
There're just stuck down with double-sided tape. I can't vouch for it's long term durability as it's just something I was playing around with.
