Leaving suspension as is
When i first picked the bike up i was intent on changing the rear shocks. Now after 6 weeks of riding over all sorts of surfaces i have decided the stock cheapo set up works well enough for me. The bike feels steady and planted on bends even going over bumps mid corner. By adjusting the way i sit i no longer feel a twinge in my back when hitting a pot hole. I am not that heavy so maybe that has something to do with it.
Anyone else got used to the suspension or am i the odd ball?
Re: Leaving suspension as is
No, I'm a heavy guy and I'm fine with the suspension as is as well. Sure, I get to know the potholes and bumps in my commute quite well, but that's true for just about any scooter or motorcycle.
I've not really had a scooter before ,unless you count the c70 I bombed about on 25 years ago , so don't know if the suspension is good, bad or whatever. I do think it's quite hard going over certain bumps thought but if he road is good I think it's fine.
I would definitely like to switch out the shocks but there are not really many options that are within a reasonable price range... So I will be stocking with the stock shocks as well. They're really not that bad anyways :-)
Well that's part of my reasoning as well. I bought the PCX to commute to my work on the cheap, but if I start replacing parts for €200 at a time, those savings evaporate instantlyese12105 wrote:I would definitely like to switch out the shocks but there are not really many options that are within a reasonable price range... So I will be stocking with the stock shocks as well. They're really not that bad anyways :-)
That is a valid point as I got the pcx as a cheap fun machine and though I did originally intend to do light modes I think I can live with tbe way it is quite happily for now....
Sent using Tapatalk
Sent using Tapatalk
I've never even thought about the suspension, seems fine to me. Although this is the first thing I've ever ridden so I've got nothing to compare to.
I've ridden a whole bunch of bikes, and the PCX has the best suspension of any scooter I've ridden, especially 2-up. I might change it eventually to give me a bit more comfort for longer rides, but I don't like the options available either. I can't justify spending several hundred on suspension, when the stock setup works great.
- EddieC
Great point. I had a Penske suspension on my last bike (sv650) and WOW.... did that make a difference. The PCX suspension is not nearly as good as that, but not horrible either... in my opinion the shocks are too soft... seeing that when my 110lb girlfriend joins me we can bottom out the suspension when going over one of many of Los Angeles's potholes. We are within the max weight limit of the scooter too so thats not the cause. This is also my first scooter so I have no other scooter to compare the stock setup to... I would like to change them out,.. but then I would have to do the front suspension to match... and we start talking about money again... The front actually performs fairly well now that I think about it, but unless we find some cheapo shocks for under $150 I think I'll be holding onto the stock setupFiah wrote:Well that's part of my reasoning as well. I bought the PCX to commute to my work on the cheap, but if I start replacing parts for €200 at a time, those savings evaporate instantly
Eddie, make sure your tires are fully inflated. We exceed the weight limit with me, my wife, the dog, and gear, and have only bottomed out a couple of times. I found out after we bottomed out the first time that my tires only had around 20psi, when they need 44, if I remember correctly. Inflating the tires made it handle much, much better too. It felt much more sluggish beforehand...
- EddieC
wait, you have 44psi in your tires??? I've ALWAYS had the front at 30 psi and the rear at 36psi, like the manual recommends. I'm pretty diligent about checking the pressure every few days. I carry a bike pump with me that works great on our little scooter tires.
44psi is on the upper end of what's recommended maybe, but when riding 2-up I'd say it's a good starting point.
- EddieC
i'm looking at my manual now.. they recommend 29psi in the front at all times.. Then 33psi in the rear if the payload is under 200 lbs, or 36psi if payload is over 200 lbs
But if you guys are riding around with over 40psi in your tires with good results... I'll try it out =]
Eddie my last bike was a 2005 sv650s I had since new. I soon got used to that suspension which was not great but did the job.
Sent using Tapatalk
Sent using Tapatalk
- EddieC
ah... you had the second generation SV. I had a 2001. About a year after I bought it I switched to the penske. True, I had gotten used to the suspension, but I found a brand new penske shock for $400.... and this was when I had disposable income, so I jumped on the deal. Racetech springs and emulators were the next mod... and WOW! the suspension can make a world of difference. Granted... that was a $750 setup... and by now I know better than to spend that much money =]
- skuuter
I've got around 6000 miles of fairly hard riding at times, and a Lota' Long Gear Loaded Day/Weekend Trips on mine. My Rear Springs have sagged ever so slightly now, and gettin' a little softer. I noticed last weekend while passing Cars and Motorcycles on The Dragon that it would "wallow" ever so slightly when trying to change directions mid-curve. I'm sure mine will get an upgrade at some point, but Honda (IMO) did a much better job on the PCX125 than any of Their other Scooters except maybe the Silver Wing 600 (I've owned most every Honda Scooter from the 50cc to the 600cc Versions at some point...!!!
- haildamage
wow! you da scooter man!skuuter wrote: (I've owned most every Honda Scooter from the 50cc to the 600cc Versions at some point...!!!
anyway, i upgraded mine to the cheaper yss gas shocks and have now finally ridden them enough to be confident that the new ones are much better than stock. been riding over and over again on the bumps that used to completely jar on the stock shocks. they felt like they were made of wood. the yss actually absorb the bumps in contrast.
sorry guys, if you are happy with the stock shocks thats fine. but lets face it, they are the cheapest shocks they could have possibly used and far below the quality of the rest of the bike!
might think about the fork springs next.
JetPilot
- Color: INVISIBLE
Hi TC3,TC3 wrote:When i first picked the bike up i was intent on changing the rear shocks. Now after 6 weeks of riding over all sorts of surfaces i have decided the stock cheapo set up works well enough for me. The bike feels steady and planted on bends even going over bumps mid corner. By adjusting the way i sit i no longer feel a twinge in my back when hitting a pot hole. I am not that heavy so maybe that has something to do with it.
I would not bother nor spend money on upgrading the suspension on a scooter with 3 inches of travel, just seems like a total waste. I think effort and money would be better spent on a more comfortable seat. If I want to ride rough roads fast, I will just get on my Motorcycle that has a 21 inch front wheel and 10 inches of suspension travel
Mike
- Year: 26 adv 160
Well I disagree completely. I'm 240 pounds, that may have something to do with it , but stock shocks on my PCX were terrible, and after owning many hondas, I've often felt at least the rears are not very good. So I bought a set of YSS Z Shocks which were about 130 bucks shipped to me and the difference is pretty substantial. Especially for exactly what I wanted ,which was better performance over speedbump's and railroad tracks. I felt the difference immediately. A year later, I still think they feel good.
