Torque Settings for Transmission Cover
Dave Bo
Does anyone know the torque setting on those little 8MM screws that hold the transmission cover on? I change my vario last night over to a NYC ( with 13 gram rollers ) and I am always afraid that I might over tighten and strip that aluminum tread. I wish there was a place to find all of the bolt torque specs for our PCX's ( short of buying the service manual $$$ ).
- dasshreddar
- Year: forzaruckuspcx
Re: Torque Settings for Transmission Cover
just snug them... probably no more than 10ft lbs
- tbln930
- Year: 2013 PCX 150
Yes. Not too tight.
SECoda/tbln930
SECoda/tbln930
Honda doesn't provide specific torque values in the manual, but gives a generic 16 ft/lb for 8mm screws (2011 Helm manual, page 1-10).
I'd err on the loose side, and use threadlocker if you're really worried.
Of note that I forgot to mention, they say you should tighten the plastic fan cover up front to a whopping 0.6 ft/lb... So don't overtighten that.
