Antifreeze
navigate40
Year: 2014 Forza 300
Antifreeze
Post by navigate40 »
I have searched the site and the net and cannot find much information on this topic.
All I can find is that the antifreeze needed for the Forza is one that is a phosphate- and silicate-free formula and compatible with aluminum engines.
Peak Long Life 50/50 seems to fit the bill. It is a phosphate- and silicate-free formula and says it can be used in all engines, including motorcycle engines from all makes and models.
Site here:
http://www.peakauto.com/products/antifr ... fe-50-50-/
My bike need topping off. I will thinking of using this. Good idea or not?
Thanks
John
Re: Antifreeze
navigate40 wrote:I have searched the site and the net and cannot find much information on this topic.
Site here:
Thanks
John
Are you really sure it needs topping up? Is it likely to freeze even if you use a twickle amount of water?
stryder123
Year: 2014 forza
Re: Antifreeze
Post by stryder123 »
You are going to need such small amounts for topping off. Why worry over it? Just go to the Honda shop and buy a bottle of the right stuff to begin with.
Re: Antifreeze
navigate40 wrote:My bike need topping off.
If its below the minimum level and needs coolant, there's a leak.
Get it looked at under warranty.
navigate40
Re: Antifreeze
Thanks
It was full, in fact, over filled. Hard to tell, unless you are shining a light from above the cap into it.
Best
J
Re: Antifreeze
Is it like the PCX perhaps, as if I remember correctly, someone suggested it shows the level better if the steering it hard over to the left such as when locked. I may have this wrong.
Re: Antifreeze
navigate40 wrote:Thanks
Best
J
You need something else to worry about.
Have you checked your tyre pressures
It's a start....
