50/50 Tires for PCX?
- tbln930
- Year: 2013 PCX 150
I use my PCX primarily for camping and maybe half of the campgrounds we go to have gravel roads in the campground and gravel around the area. I really don't use the PCX for interstate high speed riding. Can anyone recommend a more appropriate tire they have actually used when a change is required. TIA
SECoda/tbln930
SECoda/tbln930
Re: 50/50 Tires for PCX?
Heidenau K66 might suit, comes in two flavours
Regular four season: http://en.reifenwerk-heidenau.com/modul ... =58&pic=60
Winter M+S: http://en.reifenwerk-heidenau.com/modul ... =98&pic=60
No idea if Heidenau tyres are available in the USA though.
- tbln930
Yes -Revzilla.com has them among others. Thanks!
http://www.revzilla.com/motorcycle/heid ... oCIrbw_wcB
SECoda/tbln930
SECoda/tbln930
MKE PCX
Revzilla HAD them is a little more accurate. Their scooter tire selection is pretty depleted at the moment.tbln930 wrote:Yes -Revzilla.com has them among others. Thanks!
It's a bummer because I haven't found any suitable US alternatives for a lot of what they carry.
- dasshreddar
- Year: forzaruckuspcx
I've said it before and i'll say it again... bigger tires will work better off road(gravel etc.).
I've gone up dirt trails with the big tires that I couldn't make with the stock tires. (deeper wider grooves I suppose)
But I would like to get some knobbier/more aggressive yet still streetable tires someday.
MKE PCX
A member of the forum named rendra is using Michellin M45 dual purpose 110/80-14 tires on both wheels to good results.
http://www.hondapcx.org/viewtopic.php?f ... ust#p29772
- relic
- Color: red white
As an off road guy - dump trucks heavy loads rough terrain
got to go radial and lower tire pressures if you have too
To me the pirelii diablo
looks like the ticket
Mr Elbows
What about for rain? What would a good tire be for the 2013 model?
Red 2013 Honda PCX 150 - very first scooter as of [2/12/15]
- MikeP
- Color: White /red
I have been running the Pireli Diabo for the past 5000k. They hold fast in the rain where as I had issue with the stock tires.
Mr Elbows
From what I've seen, there are websites that sell those tires. But they sell the front and rear tire separate.... and there's a bunch of different sizes to choose from for each tire. How does one go about choosing the right size? I'm guessing the tire size is located on my stock tires and I simply just need to go check?MikeP wrote:I have been running the Pireli Diabo for the past 5000k. They hold fast in the rain where as I had issue with the stock tires.
Rear is 100/90-14
Front is 90/90-14
Michelin City Grips are probably the best.
Front is 90/90-14
gregsta
- Color: red
gn2 wrote:Rear is 100/90-14
Front is 90/90-14
You see them sizes you posted, are they the same for all brands of tyre not just michelin and are they the correct size for a 2014 model? one more thing I have a 125cc.
AFAIK the sizes are the same for all models of PCX
The size is the same for all brands.
gregsta
- Color: red
Heidenau K66 100/90-14 RF TL 57P M/Cgn2 wrote:AFAIK the sizes are the same for all models of PCX
Heidenau K66 90/90-14 RF TL 52P M/C
Could you confirm these are the right spec before I order.
Its your purchase, so up to you to check.
gregsta
- Color: red
I done my order by the spec you recommended not a issue if you don't know and thanks for your help.gn2 wrote:Its your purchase, so up to you to check.
- ScooteringAbout
Your PCX manual should have the recommened tyre size, I had my dealership that provided the bike fit City-Grips front and back, afaik they are the same size as the stock tyres that come on the bike. I have done 1,200miles on them in a month and a bitgregsta wrote:I done my order by the spec you recommended not a issue if you don't know and thanks for your help.gn2 wrote:Its your purchase, so up to you to check.
aka DrewJW
gregsta
- Color: red
I just looked in the owners manual and it looks like I have the correct size finger cross I have or that one expensive mistake.DrewJW wrote:Your PCX manual should have the recommened tyre size, I had my dealership that provided the bike fit City-Grips front and back, afaik they are the same size as the stock tyres that come on the bike. I have done 1,200miles on them in a month and a bitgregsta wrote:I done my order by the spec you recommended not a issue if you don't know and thanks for your help.gn2 wrote:Its your purchase, so up to you to check.and in heavy rain, or A-Road cruising they've been brilliant.
Its these ones?
http://www.moto-tyres.co.uk/cgi-bin/rsh ... zeugart=MO
They're the right size. I haven't heard any reports on the make though. I believe they make winter tyres in that size as well.gregsta wrote:Heidenau K66 100/90-14 RF TL 57P M/Cgn2 wrote:AFAIK the sizes are the same for all models of PCX
