front mudguard
freshers
- Color: silver/grey
front mudguard
When I purchased my 2011 pcx125 the seller told me the front mudguard was rubbing on the front tyre due to the tyre being new. It's still rubbing, does anyone know how I can adjust it to move it away from the tyre?
Re: front mudguard
Front mudguard? Fender. What size tire is on the front now?
freshers
Re: front mudguard
100/90 14. Sorry mudguard, UK term as opposed to fender, US term!
Re: front mudguard
You've got the wrong size tyre fitted, should be a 90/90-14 so its simply too wide.
There's nothing to adjust, you'll need a new correct size tyre.
http://www.tyretectrading.co.uk/catalog ... e_weight=6
Re: front mudguard
That was easy
Curious now, what size tire is on the rear?
freshers
Re: front mudguard
Same size on the rear which hopefully is right! Looks like I need to speak to the previous owner!
Re: front mudguard
Yes, you should. Get 'er done
Rear tire is correct.
Good luck!
Good luck!
Re: front mudguard
I have a 120/70 14 on the front of mine without rubbing. It must be the 90 that is causing it. My rear tire/tyre is 140/70 14freshers wrote:100/90 14. Sorry mudguard, UK term as opposed to fender, US term!
