2015PCX - Which "brackets" fit the Givi topboxes?
forza300
Post by forza300 »
Hi Folks,
I'm trying to get a bracket to fit givi E300B for the new 2015 PCX (white of course but the red looks very very nice in the sun after I spotted a rider the other week).
I know that there are a few brackets from Givi, Kappa and genuine Honda bracket (Shad?) but would all of them be suitable to mount the Givi box or do I need the specific Givi part? Your advice appreciated.
From what I can see the box base-plates are all similar (yet different) and screw to the bracket so are they all interchangeable?
Cheers!
Re: 2015PCX - Which "brackets" fit the Givi topboxes?
If you buy a new Givi case it comes with a base plate.
This plate bolts to the model specific mounting kits, or you could be creative and make your own.
Givi's mount kit is part SR1136 and is the same part for all PCXs.
Revzilla has it in stock for around $50
http://www.revzilla.com/motorcycle/givi ... 125-pcx150
forza300
Post by forza300 »
Thanks gn2, sounds a bit better than $170 for the Honda one!
forza300
Post by forza300 »
... and I ordered the last one (from Revzilla) on the shop floor too.... PHEW !!!!
BrAtKo
Post by BrAtKo »
Hello you can easily install this original Honda US trunk as I did (because it is massive a good looking). Here is the how to do it http://hondapcx.org/viewtopic.php?f=3&t=947
I've already sold my PCX and swapped to NC750S DCT
tbln930
Year: 2013 PCX 150
Post by tbln930 »
Now I went with the Givi mount plate and the only advantage I can see to it is the holes for using bungee cords when the case is not mounted. The metal Givi brackets are completely hidden by the Givi mount plate. I really don't plan on taking the case off much. Likewise, I think you could fly the bike around by mounting a wing on that Givi plate and brackets. Strength isn't an issue.
SECoda/tbln930
forza300
Post by forza300 »
Ta-taaaaa .....
Done! And very nice indeed
