Too low to the ground (hitting speed bumps)
Cambo PCX 150 (2014)
Post by Cambo PCX 150 (2014) »
Satisfied with the new PCX 150, but only with one big disadvantage of small distance between bike and road, which I didn't read about before. Does anybody else experience this? and are there known solutions?
I have to say that Cambodian roads are not famous for having the most smooth surface, but the problem is with those small speed bumps on the road that are found in many countries. My old Suzuki never had this problem. It is a bit disappointing and worrisome as a pipe from the tail pipe is the first to hit the concrete.
I hope anyone have some advice on this.
Re: Too low to the ground (hitting speed bumps)
Haven't had a problem. Either I ride around them or drive over at a speed that doesn't cause the bike to bottom out.
Jeffrey
Post by Jeffrey »
My exhaust pipe was starting to wear from rubbing on the road curbing so I welded a piece of steal where is was rubbing, I thought it would be easer than trying to fix a hole.
I think it is a bad design fault.
Thx Jeffrey. I agree it is a design fault. I'm thinking to take your advice.
buddy1976
Post by buddy1976 »
had my pcx 2 years, still yet to experience this issue
Honda forza 125 2019
Yellow malossi contra spring
Malossi delta clutch and bell
Malossi special kevlar belt
K and n air filter
Akrapovic exhaust
Malossi White Contra Spring
Malossi yellow clutch springs
Daytona reinforced belt
DNA Performance air filter
Removed air box flange
Removed seat hump
Ermax+25 windshield
Steph
Year: 2013 150cc
Color: Black PCX
Post by Steph »
I do encounter speed bumps very infrequently. But, when I do I slow way down and glide over them without a problem.
buddy1976
Post by buddy1976 »
now i get ya
now i get ya
K and n air filter
Akrapovic exhaust
Removed seat hump
Ermax+25 windshield
Now THAT is a speed bump!!!
Tyre blow outs. Has anyone worried about those yet? Someone should!!
Does it need a new thread?
@ buddy76 LOL!! :lol:
Talk about speed bumps? Arg! I live in a large condo community. Once I rode "the longer way out" of here, I counted 22 of them. I know there must be 50 or so in total...each 2 short blocks apart. We do not lack for Stop Signs either. Plenty! As I enter and leave my driveway there is a "bump."
How do I deal with them? I make it a game.
I'll practice as Properly taught: I brake and set my speed prior to it, then release brakes raise butt and ride over. Once over, Sit my butt back down and apply throttle accordingly. Then the next one appears, I slowdown and ride through the narrow opening at the side (near the curb). I do this on my bicycle's, so....why not with the skinny scooting tires? Fun! :D I do weave down the streets between them and then I choose which side of the next bump to squeeze between. I know, sometimes that puts me on the wrong side of the road :D but....what the heck, it's fun and makes for a challenge!
O.K. Confession: I DID wallop my butt and scape the underside ONCE going over one of them. Duh!! I was bored doing it "properly" over and over...so I sped up and.... :|
Well,...that's How I developed my different speed bump ways :D
you you wrote:Tyre blow outs. Has anyone worried about those yet? Someone should!!
Start one :D
Start one :D
It's that or front wheel bearing failure. What do you think?
frog13
Post by frog13 »
Perhaps fashion a type of skid plate or bar reference the exhaust .
Thx Frog.....I will get some plate installed
