Hi folks,
I'm going to try replacing the old belt on my 2011 PCX 125.
I seem to remember that recommended torque on the nut holding the variator assembly in place is 44 lbs.... But don't know about the nut for the clutch. Could someone enlighten me?
(If anyone has any tips for swapping out belts too, please lay 'em on me. Is it as simple as just tossing the new belt on, and tightening the two nuts? Or do I need to tighten a bit, squeeze the belt to reseat it higher/deeper in the pulleys, tighten a bit more, etc. etc.?)
What is recommended torque for the clutch nut?
- Year: 2011 PCX 125
SCOOTS
Now: 2013 Honda PCX 150 / 2011 Honda PCX 125 / 2014 Honda Metro / 2014 Honda Metro
Before: 2015 Yamaha SMAX / 2009 Yamaha Zuma 125 / 2006 Yamaha Vino 50 / 2013 Honda Metro
WOOTS
1988 Volkswagen Westfalia full camper
WOOTS
Re: What is recommended torque for the clutch nut?
The Clutch outer nut is 36 ft lbs. in my 2013 manual.
Thank you good sir!SECoda wrote:The Clutch outer nut is 36 ft lbs. in my 2013 manual.
SCOOTS
WOOTS
WOOTS
The nut is a metric size so it'll need to be torqued in kg/m
That's good.
gn2 wrote:The nut is a metric size so it'll need to be torqued in kg/m
very naughty
