Koso Mini Tach
Koso Mini Tach
Where did you mount this guy? Temp or perm? TIA
- sendler2112
- Year: 2013 PCX150
Re: Koso Mini Tach
Mines still on the bars and routes down the steering column. Until I find a better place I guess it will be a permanent accessory. Go ahead click on my video and FEED ME
My valve adjustment video is going to rack up some serious hits this year
- MikeP
- Color: White /red
Re: Koso Mini Tach
I used velcro to fasten the tack. I like the position because my eyes can see my speed in relation to the RPM with ease. Put it on last weekend and am very happy with it so far.
- image.jpg (75.83 KiB) Viewed 7011 times
Re: Koso Mini Tach
Thanks everyone. I kind of like the third one so far. I was actually considering a center handlebar mount but I like below the speedometer.
I guess running the wire is a pain?
- MikeP
- Color: White /red
Re: Koso Mini Tach
It was not too hard, I removed the windshield, the electrical cover below that and the gas door/ pannel.Then I was able to fish the wire thru with ease. Check that the wire into the tack is sealed. Mine was not and I could see the two wires when I flexed the joint. Thus I heat shrunk the connection for extra water resistance. Good Luck
Re: Koso Mini Tach
Thanks. I have tons of black heat shrink and have had all of that stuff off before!
- sendler2112
- Year: 2013 PCX150
Re: Koso Mini Tach
Tell her it has to work good. Not look good. You have to take your eyes far down, off the road to see it on the bars. Rpm versus speed is the pertinent information that you need.
Re: Koso Mini Tach
As luck would have it my wife is getting a Galaxy Note 4 on her upcoming upgrade (it holds my large phone as well) so I needed the next larger phone holder (not nearly as large as that photo makes it look
). Anyway the tach aligns perfectly for viewing. Some Velcro and nylon ties. I am planning a quick disconnect with the bag of wire harness terminal connectors I got off of EBay for the Forza's Givi lights.
My view of the tach. Turning it blocks nothing.
- wingz
- Color: Dark Silver
Re: Koso Mini Tach
Thanks for the inspiration, dudes.
I quickly bought a TTO tach and copied Mike's mounting position.
Re: Koso Mini Tach
Can you hide that wire?
- wingz
Re: Koso Mini Tach
I'm thinking one might be able to mount it behind the "glass" and drill a hole behind the tach for the cable.
Fortunately I'm the only one who rides my scoot so the only complaint I hear is that I have wasted money on unnecessary shite.
Re: Koso Mini Tach
You have a near color match. lol
piolob
- Year: 125 cc MY2015
- Color: red
Re: Koso Mini Tach
I installed the tachometer behind the windscreen,
no cable in front of the dashboard and better protection from the rain.
- IMG_20150114_120545.jpg (256.12 KiB) Viewed 6861 times
