Ordered Givi V47, SR1123, and E134S Back Rest
SECoda
Honda Forza 300 &
Honda Forza 300 &
Post by SECoda »
I went with the carbon fiber trim. (SportTour.com in Ohio)
GIVI SR1123 Monokey Topcase Rack - Honda Forza 300
V47 Topcase Versions (choose one): V47NN (matte black)
V47 Options: Backrest Pad (E134S)
blackcat54
Re: Ordered Givi V47, SR1123, and E134S Back Rest
Post by blackcat54 »
Pics...when you get it...please.
Monty1952
Post by Monty1952 »
SECoda wrote:I went with the carbon fiber trim. (SportTour.com in Ohio)
No LED light package SECoda?
2014 Forza - Silver 2,300km
2013 BMW C600 Sport 0km!
stryder123
Year: 2014 forza
Post by stryder123 »
I checked out that web page. I have also been thinking about getting that v47 top case. I have one question though. On the rack I see there is a sr1123 and a sr1123mm any idea what the difference is?
No difference listed in the product description.
stryder123 wrote:I checked out that web page. I have also been thinking about getting that v47 top case. I have one question though. On the rack I see there is a sr1123 and a sr1123mm any idea what the difference is?
Seems to indicate one is for the monolock Givi cases and the other for the monokey case.
Monokey is the patented locking system that GIVI uses. One key can be used to lock/unlock the case and remove it from the mounts with the added option of matching all GIVI cases on your bike to the same key. It is also the name used for GIVI’s premiere series of cases.
The MonoKey series are actually the top of the line series with a more substantial mount, more features, and better quality construction. MonoKey mounts are sold separately.
Monty1952
Post by Monty1952 »
I think if you go Monolock you save relatively little weight and the mounting pegs are far less stable. Unless you are very much budget restricted go Monokey.
SECoda
Honda Forza 300 &
Honda Forza 300 &
Post by SECoda »
Yes go Monokey! That is their best. I should get delivery on Wednesday.
I have not decided on which light kit yet. I like the Admore (brake and turn). There are others to consider.
http://admorelighting.com/store/index.p ... uct_id=176
http://www.twistedthrottle.com/admore-l ... 7-topcases
https://www.youtube.com/watch?v=lfJ6Qzj6J_s
Share your intentions while you share the road with the Admore Lighting LED kit.
•Provides additional and very bright tail, brake and turn signals
•High output Red and Amber LEDs
•Red running and brake lights
•Brake lights flash 3-4 times prior to full on (optional)
•Amber turn signals (wicked blinkahs for yah New Englandahs)
•Topcase specific design
•No permanent topcase modifications required
•Weather-proof connectors
Includes:
•2 high-intensity bi-color LED arrays
•Mini controller with turn signal functionality
•Power harness
•Weatherproof quick-disconnect connectors
•Detailed instructions
•Premium wire tap connectors
SECoda
Honda Forza 300 &
Honda Forza 300 &
Post by SECoda »
I decided to go with the Admore lighting. I may mount the box arriving today until the lighting arrives.
SECoda
Honda Forza 300 &
Honda Forza 300 &
Post by SECoda »
Ordered from Revzilla for the first time. $125.10 and free shipping. Twistedthrottle was out of stock.
SECoda
Honda Forza 300 &
Honda Forza 300 &
Post by SECoda »
Very nice but I guess it should be for the $$$. Needs lights. :P
SECoda
Honda Forza 300 &
Honda Forza 300 &
Post by SECoda »
That case looks so wide and large on my dining table but matches the width of the Forza when I put it on the rear seat. :? The case and mount are made in Italy but the seat back in Thailand. All very high quality.
SECoda
Honda Forza 300 &
Honda Forza 300 &
Post by SECoda »
AdMore lighting shipped for a Monday 12/22 delivery. Just-in-time for vacation. With snow in the air I may move the Forza into the walk-out basement for some accessorizing.
SECoda
Honda Forza 300 &
Honda Forza 300 &
Post by SECoda »
Install. Will need to go back at it when the lights arrive. Actually, the most difficult part of it was drilling the holes. A drill press and large bits up to 20mm made it a lot easier. You just use masking tape and go slowly up in size.
Monty1952
Post by Monty1952 »
Looks good SECoda and drill press would certainly make it easier. Not unhappy with my silver version of box but carbon is cool. For anyone considering this setup it's probably a 20 minute job although I took my time being careful and about 30 minutes.
SECoda
Honda Forza 300 &
Honda Forza 300 &
Post by SECoda »
How was hooking the lights up. They arrive on Monday?
SECoda
Honda Forza 300 &
Honda Forza 300 &
Post by SECoda »
A few Pictures outside in the daylight.
blackcat54
That looks great!
Beautiful bike.
SECoda
Honda Forza 300 &
Honda Forza 300 &
Post by SECoda »
The AdMore Lighting Kit has arrived including a drill bit. :o
SECoda
Honda Forza 300 &
Honda Forza 300 &
Post by SECoda »
I plan on using some old airplane wiring clips to hold wire out of the way. Slow but sure. :)
SECoda
Honda Forza 300 &
Honda Forza 300 &
Post by SECoda »
I think I am going to borrow Dennis's idea in a previous thread and use an adapter so I don't have to splice so many wires in. Great idea!
http://www.hondapcx.org/viewtopic.php?f ... 946#p44556
