Is there a bar that spans between the curve of the handle bars just below the eyeline of the speedometer that you can attach either a mobile phone or Sat Nav to?
If so....any ideas what it is called?
Mobile Phone and Sat Nav Bar
Aberdeen Scoot
- Color: RED
Re: Mobile Phone and Sat Nav Bar
Those bars are fairly thin (I have one). I would be surprised if you found a holder that has a bracket that is small enough in diameter.
I believe that I saw some advertised by powerbypcx.com. Let me do a quick check....OK, I found it. Here is the link:
http://www.powerbypcx.com/achat-guidon- ... 79939.html
The key to the question is not necessarily about a bar that fits across the handle bars, but one that a phone of nav mount can be attached to. That's why I made my previous comment. I can't recall seeing a phone or nav mount that has a small enough diameter mounting bracket for the small diameter of the cross bars.Aberdeen Scoot wrote:Is there a bar that spans between the curve of the handle bars just below the eyeline of the speedometer that you can attach either a mobile phone or Sat Nav to?
Just duct tape it to your visor.
If you're clever you'll leave enough space to see some of the road.
Aberdeen Scoot
- Color: RED
Looks like i will have to fab one myself.....if its any good, i will be tsking ordeers!!
- DAB
Got a renthal brace on mine, just for this purpose.
Other rides
Aberdeen Scoot
- Color: RED
Got the renthal Brace and fitted it, workd a treat..... Thanks for the advice Benefactor
