Dyno boost performance chip
gia
Post by gia »
PCX170 2013
Re: Dyno boost performance chip
Performance may be improved in terms of acceleration and top speed, but the info says it tricks the ECU by pumping in more fuel - greater acceleration, etc, but also states greater fuel economy in the same paragraph - can't all be true.
Urbanfreestyle
Year: 2014 (UK)
Post by Urbanfreestyle »
This is more than likely a variable resistor with a box and some wires for good measure. NO WAY would i pay that much for it! it goes along the same lines as electronic superchargers and magnets on your fuel lines.
Honda PCX 125 ESP (Black)
nribeiro
Post by nribeiro »
Strange thing is I don't see an IAT sensor in PCX...
Anyone knows?
In my car it's before the TBI but in PCX does not seem to have that sensor before the TBI.
sendler2112
Year: 2013 PCX150
Post by sendler2112 »
The Honda fuel injection system for all of the sub 300cc bikes is very compact. Honda made a big deal out of this concept when it was proposed back in 2000. They looked around and still saw stinky carbureted bikes everywhere and wanted to bring fuel injection with a narrow band O2 sensor to the masses in Asia and India. The IntakeAirTemp, ThrottlePositionSensor, and ManifoldAbsolutePressure sensors are all surface mounted onto the main board at the throttle plate to make it as compact and inexpensive as possible.
I wouldn't buy that ebay thing. If you don't make a major mod you won't gain anything with even a good fuel controller like the Bazzaz. If you add displacement and change cams, you won't gain much without one.
http://www.bazzaz.net/index.php/honda/pcx150-12-15
http://www.bazzaz.net/index.php/fuel-co ... elf-mapper
