Hi
I have a PCX 125 that has an odd starting fault. The bike will start fine for the first time, then after running the engine for even a very short time, if I shut the engine off and try to start again it will not turn over. If I leave the bike without trying to crank it for at least 20 minutes It will then start fine the next time I try.
When the engine is running all is good, you can ride it about as normal (no cutting out) but soon as you stop to pop into a shop etc it will not start for at least 15-20 minutes.
Anyone had of heard of an issue like this?
I am baffled.
NT
PCX 125 (2021) Intermittent starting fault.
