I was considering a lithium replacement. I'm in GA and I don't ride when it's below 50f (so no real cold starts) but the scoot does sit between Sept-ish and April-ish and it would be nice not to have to trickle-charge or remove an AGM every winter.
On the other hand, I don't want to spend a fortune on a battery.
I saw the Noco NLP5 and while CCA and volts are good (250CCA/12v) I don't know whether the Ah are enough. It's rated at 2Ah which seems a little low... but I'm no mechanic or electrical engineer.
So... are 2Ah enough? If not, what should I look at for a lithium?
FWIW, the Noco is about $110 with separate charger so it's not a bank breaker. I'd probably go up to $150 if the features could justify it - but I really just want something that works, is reliable and convenient
Any advice? Thanks
