Had a low speed crash on Aug 4th, dinged up my PCX a bit.
Here's the damage(best I can tell):
From what my brother tells me, the rear brake lever is slightly loose, and he insists the front wheel is also a bit loose.
Any specific tools needed to tighten those? I have a Victorinox Multi-tool, philips and flat-head screwdriver, and a simple adjustable wrench. I plan to buy the replacement parts and have my dealer do the install, which is just as well since I need them to run a check on the overall function, but at the same time, I kind of wanted to make sure I could ride it 5 miles to the dealer safely(in full gear this time) without something coming apart on the road
 .Dealer tells me parts for the 2015 PCX are not yet available, though WhiteNoise did direct me to this site:
http://www.cheapcycleparts.com/oemparts ... 0-ac-parts
I didn't catch it on the photo, but there's a crack just above the glovebox cover, but the cover itself seems to be fine. Also some scuffs to the back of the left mirror.
From what I can tell, I'd need:
http://www.cheapcycleparts.com/oemparts ... 2ce/mirror
-Part 4
http://www.cheapcycleparts.com/oemparts ... ront-cover
-Part 5(White)
http://www.cheapcycleparts.com/oemparts ... nner-cover
-Part 7?(White) This one not too sure as the wire diagram of the part in question doesn't seem to match what I see in the photo, but only the white plastic was damaged, so it's only either 7 or 8.
I don't believe any screws were damaged, so I won't be ordering any of those. If anything, it just looks like the plastic panels were dislodged from the latch on impact.
Anything else I missed that you guys see? Anything else I should check before attempting to ride it to the dealer? It's still a ways away before I can ride, given the broken bones in my left leg, maybe another month, give or take a few weeks. I'll do some short laps around the parking lot first of course.
