has anyone got NCY CVT sliders?
Re: has anyone got NCY CVT sliders?
mikelx5 wrote:its close slides not sliders
What are close slides?
So they are.
So a standard cvt like ours usually has one set of sliders and one set of rollers I guess.
- Year: 2013 - 150
Looks like they both do the same thing but rollers are round so they roll, sliders are not round so they slide. It's either/or, not both.
https://www.google.com/search?q=cvt+sli ... 07&bih=482
https://www.google.com/search?q=cvt+rol ... 07&bih=482
Slider vs roller:
Back to the original subject now. I have no idea on the fit, the new sliders certainly look different though. Did you send a picture to the seller?
Slider vs roller:
Duggle wrote:Looks like they both do the same thing but rollers are round so they roll, sliders are not round so they slide. It's either/or, not both.
Slider vs roller:
wires=crossed
Honda forza 125 2019
Yellow malossi contra spring
Malossi delta clutch and bell
Malossi special kevlar belt
K and n air filter
Akrapovic exhaust
Malossi White Contra Spring
Malossi yellow clutch springs
Daytona reinforced belt
DNA Performance air filter
Removed air box flange
Removed seat hump
Ermax+25 windshield
K and n air filter
Akrapovic exhaust
Removed seat hump
Ermax+25 windshield
- Year: 2013 - 150
I'm new to scooters and cvt stuff, I'm used to gears and shifting. Am I wrong on my post? I got the feeling that scooters don't have one set of rollers and one set of sliders.
buddy1976 wrote:Duggle wrote:Looks like they both do the same thing but rollers are round so they roll, sliders are not round so they slide. It's either/or, not both.
Slider vs roller:
wires=crossed
ok guys seriously way off my subject , anyway you guys keep getting this wrong , i am not talking about dr pulley sliders , a normal stock variator has rollers and "CVT" sliders in it , look at my post up top at the pic of the CVT SLIDERS , anyone taking part the variator should know this
I know what you mean. Yes they do look different don't they.
- sendler2112
- Year: 2013 PCX150
Why replace those already? Send the wrong ones back and just keep the originals. And install 12 gram DrPulley sliders in place of the rollers.
already? well they are sorta sticky the bike has over 18k on it , and why 12mg dr pulley? i went from 15 gram rollers to 17 gram dr pully and gained 3 mph , if anything like my ruckus if i go to 12 mg ill go like 55 mphsendler2112 wrote:Why replace those already? Send the wrong ones back and just keep the originals. And install 12 gram DrPulley sliders in place of the rollers.
MaLLoc wrote:already? well they are sorta sticky the bike has over 18k on it , and why 12mg dr pulley? i went from 15 gram rollers to 17 gram dr pully and gained 3 mph , if anything like my ruckus if i go to 12 mg ill go like 55 mphsendler2112 wrote:Why replace those already? Send the wrong ones back and just keep the originals. And install 12 gram DrPulley sliders in place of the rollers.
I have used 11gr dr pulleys in stock variator on my 2013 esp 125 and lost no top end, in fact it gained 1 or 2mph top end and slightly better acceleration. if you want to make a bigger gain in top end buy a performance variator and new belt. The stock weights were 18gr when i purchased it new and had the acceleration of a skateboard!
K and n air filter
Akrapovic exhaust
Removed seat hump
Ermax+25 windshield
K and n air filter
Akrapovic exhaust
Removed seat hump
Ermax+25 windshield
Just re-read the thread.......my badbuddy1976 wrote:MaLLoc wrote:already? well they are sorta sticky the bike has over 18k on it , and why 12mg dr pulley? i went from 15 gram rollers to 17 gram dr pully and gained 3 mph , if anything like my ruckus if i go to 12 mg ill go like 55 mphsendler2112 wrote:Why replace those already? Send the wrong ones back and just keep the originals. And install 12 gram DrPulley sliders in place of the rollers.
K and n air filter
Akrapovic exhaust
Removed seat hump
Ermax+25 windshield
K and n air filter
Akrapovic exhaust
Removed seat hump
Ermax+25 windshield
