is the 2013 gauges ( dash ) interchangeable to the 2011?
just wondering if i can swap the dash from 2013 into the 2011 , just looking to replace , not because i want a newer one because i think its better.
thanks
thanks
Re: is the 2013 gauges ( dash ) interchangeable to the 2011?
I think you're confused, the 2011 and 2013 are the same.
The 2014/15 is different and probably will not be interchangeable.
gn2 wrote:I think you're confused, the 2011 and 2013 are the same.
There not
there not? as in which ones , the other guy mentions 2014 so i dont know what ones your saying there not to .you you wrote:gn2 wrote:I think you're confused, the 2011 and 2013 are the same.
There not
GN2 is saying the new 2014/15 (depends what people call it) with LED lights, new body shape, larger fuel tank, better battery, intelligent idle-stop, and extra bhp for the white colour model (lol) is very different in terms of replacement or interchangeable parts from earlier PCX's such as the 2011/2013 models which are quite similar in many repects. The newer, older models changed to an ESP engine (I believe) and one change I know of is the centre stand fix on ESP models to stop it breaking off! Body panels may be swappable between both sets of older models, or at least in the main.
uhm i dont know why anyone at all keeps talking about 2014 i asked a very specific question
is the 2013 gauges ( dash ) interchangeable to the 2011? simple as that
Probably as the first reply said they were basically the same, and then a follow-up said not so. That's where the 2011-3 similarities compared to the latest model came in. It may be wise to try one of the many PCX parts outlets, choose your model/year and see what it offered - if it's the same part no then probably ok.MaLLoc wrote:uhm i dont know why anyone at all keeps talking about 2014 i asked a very specific question
The 2011 dash is exactly the same as the 2013 one so I can't see why you would think its better?
i never said i am looking for better as stating in my first line postgn2 wrote:The 2011 dash is exactly the same as the 2013 one so I can't see why you would think its better?
( is the 2013 gauges ( dash ) interchangeable to the 2011?
thanks)
, i need to replace mine that is a 2011 and needed to know if i bought a used 2013 dash if it would fit
They are the same part.
37200-KWN-305
37200-KWN-305
THANKSgn2 wrote:They are the same part.
37200-KWN-305
buddy1976
Yes it will, just don't expect it to be "better" than the 2011 versionMaLLoc wrote:is the 2013 gauges ( dash ) interchangeable to the 2011?
thanks
Honda forza 125 2019
Yellow malossi contra spring
Malossi delta clutch and bell
Malossi special kevlar belt
K and n air filter
Akrapovic exhaust
Malossi White Contra Spring
Malossi yellow clutch springs
Daytona reinforced belt
DNA Performance air filter
Removed air box flange
Removed seat hump
Ermax+25 windshield
K and n air filter
Akrapovic exhaust
Removed seat hump
Ermax+25 windshield
MaLLoc wrote:there not? as in which ones , the other guy mentions 2014 so i dont know what ones your saying there not to .you you wrote:gn2 wrote:I think you're confused, the 2011 and 2013 are the same.
There not
2014/15 dash is completely different to the earlier PCXs
I think he meant that it is better to have a newer one (2013) than an older one (2011), not that the 2013 is better than the 2011.
Maybe depends on which has had the most use rather than age?
Thread Gone Crazy!
2011 dash same as 2013 period. Why change? Op's business. Use imagination if you must. Broken?
2014 or 2015, Not in the game.
Play Ball
Time to Laugh!!
http://m.youtube.com/watch?v=K0Jg7pvVzKk
Play Ball
