I have just purchased this item http://www.ebay.co.uk/itm/181468021510? ... 1439.l2649 and am waiting for it to get posted to me.
After further research I have found out this fits a UK 2011 pcx. Will this fit my uk 2013 esp and more importantly will it work like it should?
Any help appreciated guys
just purchased a YOSHIMURA exhaust system will it fit?
buddy1976
Honda forza 125 2019
Yellow malossi contra spring
Malossi delta clutch and bell
Malossi special kevlar belt
K and n air filter
Akrapovic exhaust
Malossi White Contra Spring
Malossi yellow clutch springs
Daytona reinforced belt
DNA Performance air filter
Removed air box flange
Removed seat hump
Ermax+25 windshield
K and n air filter
Akrapovic exhaust
Removed seat hump
Ermax+25 windshield
Re: just purchased a YOSHIMURA exhaust system will it fit?
No. It wouln't even fitbuddy1976 wrote:I have just purchased this item http://www.ebay.co.uk/itm/181468021510? ... 1439.l2649 and am waiting for it to get posted to me.
Not sure it would. The front pipe section is different I think. If it's been posted then try it when you get it. The ESP engine is completely different to the early 2011
I am aware from experience that the 125 and 150 are different, but I do not know about the 2011 compared to the 2013. If you are in the UK, are not all PCX's 125's? If so, you might be in luck.
- Urbanfreestyle
- Year: 2014 (UK)
Yeah they're 125's but the esp (2013) model has the same exhaust design (top pipe) as the 150
Honda PCX 125 ESP (Black)
buddy1976
Thanks for your replys. I'm thinking the same as you guys that the uk esp 125/150 has many different parts to its predecessors, o well it was a bargain so will take it to a fabricator see what can be done!
K and n air filter
Akrapovic exhaust
Removed seat hump
Ermax+25 windshield
K and n air filter
Akrapovic exhaust
Removed seat hump
Ermax+25 windshield
