Forza rear brake
Posted: Fri Jul 18, 2014 11:42 am
Just back from the ever helpful Ecosse Honda Shoppe in the big city.
The Forza had developed a pulsing effect in the left brake lever, this was confirmed to be a warped disc as I suspected and a new one with pads has just been fitted under warranty.
They also found a dud brake light switch, swapped that and changed the dipstick o-ring which was found to be not sealing very well.
Forza owners might want to keep an eye on their rear caliper, check its not sticking when you rotate the wheel.
Re: Forza rear brake
Posted: Fri Jul 18, 2014 12:56 pm
by Cbus
thanks for the heads up! I'll keep an eye on mine. How many miles on yours?
Posted: Fri Jul 18, 2014 1:12 pm
As of today 18 July, 10,200-ish miles.
Posted: Fri Jul 18, 2014 7:32 pm
by waybar
gn2, you've got over 10,000 miles, just curious how long did your tires last before you had to change them?
Posted: Sat Jul 19, 2014 1:00 am
Front still on and loads of tread left, rear changed at 7400
Posted: Sat Jul 19, 2014 1:51 pm
by powpilot
Thank you for the alert!
