Just back from the ever helpful Ecosse Honda Shoppe in the big city.
The Forza had developed a pulsing effect in the left brake lever, this was confirmed to be a warped disc as I suspected and a new one with pads has just been fitted under warranty.
They also found a dud brake light switch, swapped that and changed the dipstick o-ring which was found to be not sealing very well.
Forza owners might want to keep an eye on their rear caliper, check its not sticking when you rotate the wheel.
Forza rear brake
Forza rear brake
Re: Forza rear brake
thanks for the heads up! I'll keep an eye on mine. How many miles on yours?
As of today 18 July, 10,200-ish miles.
gn2, you've got over 10,000 miles, just curious how long did your tires last before you had to change them?
Front still on and loads of tread left, rear changed at 7400
Thank you for the alert!
