Bigger tire questions answered
Mgalutia88
- Year: 2013 PCX 150
A short list of things I thought of for refference to our bikes.
I am excluding the stock size knowing better than Honda part here because we do need to keep in mind that the bike was designed for fuel efficiency including the factory installation of "low rolling resistance" tires. ie Toyata Prius
1. Do larger tires fit? - Yes, with 4-5 washers and longer bolts spacing out the airbox and the inner fender removed. (A new fender is $6.00 from the local dealer here.)
2. Do larger tires affect ride? - Yes, the ride is less harsh and the "bigger is better" placebo definetly helps. Also stability is increased from the larger rotating mass so highway riding is more enjoyable.
3. Will I loose performance - Yes. 2-3 miles per gallon. Also the speedometer will be off by several mph. Acceleration is ever so slightly hindered. Top speed will be reduced by SEVERAL mph because of the larger mass being moved.
I would definetly suggest larger tires to those with bore kits installed.
Re: Bigger tire questions answered
What tire size do you use? on OE rims? R13 rims for the PCX is see for sale are all bad looking, imho.
Mgalutia88
I'm running a 120/70-14 front and a 140/70-14 rear.
FYI power by pcx sells a 13" version of the stock rims.
Same size as mine, and I love them. City Grips.Mgalutia88 wrote:I'm running a 120/70-14 front and a 140/70-14 rear.
Mgalutia88
kramnala58, if you put your pcx on the center stand and twist the throttle, does the rear tire move in and out? or is it perfectly steady and balanced?
I have found that the Pirelli 140/70-14 vibrations are canceled at highway speed, BUT they CRACKED one of the three exhaust mounts. I am going to order Pirellis in the stock size and see what I think. Then I will be able to give an opinion between sizes on NEW tires.
- dasshreddar
- Year: forzaruckuspcx
Mgalutia88 wrote:kramnala58, if you put your pcx on the center stand and twist the throttle, does the rear tire move in and out? or is it perfectly steady and balanced?
cracked exhaust mount from the tire
Mgalutia88
I'm pretty convinced it's the shop I took them too. They didn't lube them all the way up the sidewall lol. I may try one last time. It's just getting annoying. I'm thinking a good bit of my speed loss is due to the unbalanced effect of the tire. At least for sure the overall diameter is slightly off lol.
Mgalutia88
Dasshredder can you also please put yours on the center stand to double check? Maybe I just have had a poor mount job.
- dasshreddar
Yeah mines running true.
Un seat the bead and lube it good.
or maybe air it down to 10 pounds or so, and just cruise around your driveway to seat it better???
Mgalutia88
Thats a unique idea dasshreddar. If it doesn't seat it all the way out it may pop it off the bead... I like lol
Mgalutia88
Well, tonight I broke the bead on the front and rear tires and used plenty of tire lube to reseat the beads. I have no change from this. I am going to contact motorcycle superstore from this point and see what they will do. I am going to try to exchange for stock size Michelin City Grips. I was talking with Pcxdemon earlier and he has also had a slight out of round issue with his stock size pirellis so I am going to say at this point I don't recomend Pirellis on our bikes in the stock sizes or plus sizes.
Again I do NOT recomend the Pirellis because of poor construction.
- dasshreddar
I would like to add... maybe just the Pirelli diablos are crap. My Pirelli gts 23/24 are fine and seem just as good quality as my Michelin city grip and Pirelli sl26 that are on my gy6/ruckus.
I was wrong I guess "you will have that 140 off in a week"
Why not try the city grip in a 140?
Mgalutia88
Not in a week. It's got 500 miles on it and I'll add more today. I think I'm going to go back with the stock size in a city grip. I was hitting an indicated 75 easy and topping at 80mph with the old dunlops. I'm interested to see what happens with a fresh tire back on...
- sendler2112
- Year: 2013 PCX150
The mass of the tire will have nothing to do with top speed. It will only change how long it takes to spin up to that speed.Mgalutia88 wrote:3. Will I loose performance - Yes. 2-3 miles per gallon. Also the speedometer will be off by several mph. Acceleration is ever so slightly hindered. Top speed will be reduced by SEVERAL mph because of the larger mass being moved.
- dasshreddar
I'm not sure what gearing you have, but with the stock gears my actual speed is 4mph faster than the speedo with the 140.
So 20mph(speedo) is actually 24 mph(gps) --- 70mph is actually 74mph etc.
Oh and if you can't return the 120 why not try that on the rear...or just keep it on the front?
Makes sense - for every rotation of the axle, a large diameter rim means more ground covered, so should outway any slight extra mass being carried. Same works for cycles - large wheels, more ground covered per rev.dasshreddar wrote:I'm not sure what gearing you have, but with the stock gears my actual speed is 4mph faster than the speedo with the 140.
- sendler2112
- Year: 2013 PCX150
This doesn't make sense either. a bigger diameter tire should increase speedo error by a percentage. 4 mph fast at 70 should be 1 mph fast at 20.dasshreddar wrote:I'm not sure what gearing you have, but with the stock gears my actual speed is 4mph faster than the speedo with the 140.
Mgalutia88
SENDLER, the real reason I probably lost several miles per hour is because of the tires being out of round. That imbalance along with an increase in mass and a low power engine means it's requires more power to turn which I'm lacking so it makes it harder to get there. I hit 77 mph today but it was not easy to get there. In contrast with the stock tires I was able to hold 70mph almost anywhere, could cruise at 75 easily and could hit 79-80 mph. With the oversize tires I cruise at 65mph at 2/3 throttle at 8000rpm.
Hi Guys,
My first post here, and a fellow 2014 PCX 125cc rider from Portugal
After coming from the SYM GTS/EVO 2 125cc world, the PCX feels a bit too unstable for me so I was looking to fit wider tires.
@kramnala58 and @Mgalutia88, did you have to change anything to fit these wider city grips to your bikes?
Thanks in advance for your answers
Ride safely
Pedro
Ride safely
Pedro
buddy1976
Stock size city grip should be sufficient, I changed mine to city grip, my scoots now scraping the road when cornering to way before worrying about about losing traction. They seem more stable in rain than the irc's do in the dry!pricca wrote:Hi Guys,
My first post here, and a fellow 2014 PCX 125cc rider from Portugal![]()
Ride safely![]()
Pedro
Honda forza 125 2019
Yellow malossi contra spring
Malossi delta clutch and bell
Malossi special kevlar belt
K and n air filter
Akrapovic exhaust
Malossi White Contra Spring
Malossi yellow clutch springs
Daytona reinforced belt
DNA Performance air filter
Removed air box flange
Removed seat hump
Ermax+25 windshield
K and n air filter
Akrapovic exhaust
Removed seat hump
Ermax+25 windshield
