This is just a simple question. I checked my coolant level but was unable to see clearly, so I removed the (clip) and took the cover off. The coolant level was fine. The clip broke and I could put another one in but a screw may be better because I'd like to be able to remove the cover without replacing clips. Has anyone else come up with a better idea? Maybe a better clip, more durable. I found pieces of a previous clip and feel the dealer might have broke one when preparing the cycle.
Yes they are. I found them on Amazon and thought I'd order some. Thanks for your reply though. I don't know why the one I tried to remove was so brittle though but as you say they are cheap.
Well around here plastic nylon retainers like these are impossoble to find but American style nylon retainers are easier to locate. Since we find it too hard to go metric like the rest of the world 6.4mm or 1/4" retainers is what you will need. I found them at the hardware store. Ordering in quantity on line from Amazon seems like over doing it but I might order some anyway. since they are 95 cents for one at the hardware and $7.99 including postage for 100 on line. This is a trivial subject but I thought I'd post it anyway.
I can't stand the stupid clips. I'd order 100, and assume you're going to eventually break the one on the battery cover as well, and have a couple of spares for when your friends do the same.
Currently ride: Nothing right now - mostly mountain biking with my boys until they're old enough to ride Previously rides: 2011 Honda PCX 125, 2005 V-Strom DL650, 1974 Vespa Ciao, 2011 Honda PCX 170 (tons of mods - takegawa 170cc big bore kit, gears, etc), 1996 Honda Nighthawk 250, 1987 Honda Spree, 2000 KTM 125SX, 2003 Honda Silverwing, 2007 Genuine Buddy 125, 1998 Honda PC800, 2008 Buddy 125 (white), 2008 Buddy 125 (red), 2001 Honda Reflex, 1987 Honda Elite, 1988 Honda Spree, 2007 Yamaha Vino, 2007 Honda Metro, 2x 125cc pure-chinesium dirt bikes
