Adding Avatar picture to the profile
Please help, I am trying to add a picture to the profile and when I reduce the picture to 100 or 120 across I have no control of the second size for the down dimension. Can someone tell me how to get the correct picture size on this site?
Thanks.
Thanks.
Live life to the fullest, ride with a smile!
Re: Adding Avatar picture to the profile
Use image editing software to make it the correct size then upload it.
Thanks, I have the ability to resize the pictures but only in one dpi direction size. The resized picture will say 100 x 85 and the forum says the picture has to be 100 x 100 or no larger than 120 x 120. I can't figure out how to make the second size the size required.
Thanks
Thanks
it was hard for me also had to have a friend do it.
Hi Folks
you can give this a try http://www.shrinkpictures.com
Look in left column, click on create avatar
I use this website a lot!
Takeoff - it seems the recommended size is a max w*h judging by peoples avatars - some are square, some aren't.
- Urbanfreestyle
- Year: 2014 (UK)
I use https://wss.rmplc.net/sites/SWGfLPartne ... 25201.aspx
as it allows a preview of the adjusted pic
Honda PCX 125 ESP (Black)
Thanks to all who offered options to add the picture, I'll give it a try and hope for positive results.
Thanks again.
Thanks again.
- Urbanfreestyle
- Year: 2014 (UK)
If need be, feel free to send me the pic and i'll adjust the size for you and send it back.
