indicator problem
Posted: Thu Jun 12, 2014 1:22 pm
by blacks88
Hi
This is my first post i am from the carribbean but living in france and i am a proud owner of
a 2014 white honda pcx 125cc
today i tried to install an alarm on my new honda pcx with no success
so i decided to mount everything back up but while i was testing the alarm
to see if it was working the blue wire for the indicator got cut so i joined
another wire to the blue wire because it was too short and i closed it back up
now after doing all of that and mounting back up the parts i took off the left
indicator stayed on and when i tried to turn it off would not repond
does anyone have an idea of what can be the problem
Re: indicator problem
Posted: Thu Jun 12, 2014 2:28 pm
by iceman
Was power on during tests when the wire got cut?
Posted: Fri Jun 13, 2014 1:25 am
by blacks88
I'm not to sure whether the power was on but I would say it was off when it got cut
Posted: Fri Aug 01, 2014 2:35 am
by ruidalves
Hello,
Did you mangar to solve your problem? I own a 2014 PCX with the exact same issue.
I was also trying to install an alarm and now the left turn signal won't stop. I disconnected all the alarm wiring and the problem remains.
Could you give me some advice on how to fix this?
Thank you
Posted: Fri Aug 01, 2014 9:46 am
by dasshreddar
any pics of the cut/repaired wires?
does the other indicator work?, if not probably fried the relay.
