indicator problem
blacks88
indicator problem
Post by blacks88 »
Hi
This is my first post i am from the carribbean but living in france and i am a proud owner of
a 2014 white honda pcx 125cc
today i tried to install an alarm on my new honda pcx with no success
so i decided to mount everything back up but while i was testing the alarm
to see if it was working the blue wire for the indicator got cut so i joined
another wire to the blue wire because it was too short and i closed it back up
now after doing all of that and mounting back up the parts i took off the left
indicator stayed on and when i tried to turn it off would not repond
does anyone have an idea of what can be the problem
Re: indicator problem
Was power on during tests when the wire got cut?
blacks88
Post by blacks88 »
I'm not to sure whether the power was on but I would say it was off when it got cut
ruidalves
Post by ruidalves »
Hello,
Did you mangar to solve your problem? I own a 2014 PCX with the exact same issue.
I was also trying to install an alarm and now the left turn signal won't stop. I disconnected all the alarm wiring and the problem remains.
Could you give me some advice on how to fix this?
Thank you
dasshreddar
Year: forzaruckuspcx
Post by dasshreddar »
any pics of the cut/repaired wires?
does the other indicator work?, if not probably fried the relay.
