Does anyone know the correct torque setting for the rear wheel hub nut.??
Cheere
Rear wheel
Re: Rear wheel
According to the Honda service manual:
118 N/m (12.0 kgf*m, 87 lbf*ft)
Re: Rear wheel
You'll need a longish torque wrench for it too, and a 24mm socket.
Tighten the nut a good bit while the scooters on it's centre stand, then take it off the stand while standing to it's left, this will mean you can apply the rear brake and lean your weight over the bike while you torque the nut. I might be teaching my grandmother to suck eggs here.
Re: Rear wheel
Any advice is good advice thanks
