Battery nut
Posted: Wed May 21, 2014 8:42 pm
by logepoge1
Lost the but that goes in the battery terminal. Where can I find a replacement and what is cheap remedy until then?
Re: Battery nut
Posted: Wed May 21, 2014 10:12 pm
by katschamne
any hardware store will have them.
Re: Battery nut
Posted: Wed May 21, 2014 10:42 pm
by logepoge1
Okay thanks. For now I wedged the battery clamp on and it seems to be working
Re: Battery nut
Posted: Wed May 21, 2014 10:43 pm
by logepoge1
I really hate those things. There has to be a better way to secure them on there. Might glue some plastic to keep it from coming out
Re: Battery nut
Posted: Wed May 21, 2014 10:51 pm
by scisor34
A dab of blue Loctite works wonders in these situations.
Re: Battery nut
Posted: Thu May 22, 2014 12:07 am
by logepoge1
Doesn't it have to move?
Re: Battery nut
Posted: Thu May 22, 2014 7:36 am
by scisor34
I might have misunderstood your issue, if it's the nut you're having issues with staying snug, some blue loctite is the answer.
Re: Battery nut
Posted: Thu May 22, 2014 8:56 am
Hey loge! Which nut?? (you nut!)
Re: Battery nut
Posted: Thu May 22, 2014 2:12 pm
by logepoge1
scisor34 wrote:I might have misunderstood your issue, if it's the nut you're having issues with staying snug, some blue loctite is the answer.
It's the but inside of the battery terminal that the bolt threads into
Re: Battery nut
Posted: Thu May 22, 2014 5:12 pm
by Alibally
Any nut that's the right tread and length will do. As long as it's tightened correctly there should be no need for thread locker. It's only to keep the wire on the terminal. It's better to be a clean thread as this gives a better connection.
