Guys,
Was wondering.. Since 2014 model has an ECU update which also gives better performance/ more revs.
Would the agent / honda will be willing to update ECU to 2014 version on pcx 150 2013?
And maybe change tires to lower lying?
cheers
ECU Update
Mgalutia88
- Year: 2013 PCX 150
Re: ECU Update
Lol probably not but worth asking. You'd need to know the new redline and roller weight. Most likely the change is in the variator since that would change the characteristics completely.
Re: ECU Update
Changing the end RPM does not change the roller weight which is designed to exploit maximum power not maximum RPMMgalutia88 wrote:Lol probably not but worth asking. You'd need to know the new redline and roller weight. Most likely the change is in the variator since that would change the characteristics completely.
Mgalutia88
Re: ECU Update
What is the new redline?
