European turn signals in US?
- 6ftMach1Girl
Is there a kit to install turn signals in the front on the US model that are like the European ones?
Re: European turn signals in US?
This is also for the rest of the world as well. I think it is only the US & Canada models that have the signal post.
One thing you would want to do is make sure the wiring harness is the same. I know that maddiedog swapped out the rear signal lights for some aftermarket ones, but they are not actual PCX lights. I suspect that with his ability, he was able to figure something out on his own.
- GeorgeSK
- Year: 13PCX,15Forza
- Color: Both Red
The other thing that you want to check is "Will they pass my state's inspection?". I got my inspection a couple of days ago and noticed a very prominent sign stating "NOTICE: many aftermarket signals DO NOT pass MA inspection".
The smooth look is cool, but not if I have to swap stuff out every spring to satisfy the man.
- dasshreddar
- Year: forzaruckuspcx
You have a spring inspection? And I thought California was a Nazi state.
I don't think there is a kit specific, you need to just swap the whole headlight/taillight
The rear indicators are a simple bolt-on.
The fronts require a complete swap of the front light unit and you'll need to find a way of blanking the holes left in the fairing or swap the affected panels.
das, you got a link to share with 6footer for a "whole headlight" swap? Or a pic of one? Will it fit proper in both the 2011 And 2013 U.S. PCX? Or will there be modifying involved? Simples?
I'm just guessing that if I were to swap out the wink-e-dinks to a full face assembly the police here wouldn't even recognize/notice. Exterior to interior indicators? Nah. As long as I winked by law prior to lefty or righty turns I sense no problem. However, it still is a risk, you will be breaking the law in NYS. Lotsa folks don't even use their winkers on any vehicle
That IS So, So Wrong!!!
Seems like gn2 was typing alongside. He hit the "submit button" a wee bit sooner than I
- 6ftMach1Girl
I only want to do the front. I was hoping to leave the US stick-outs to remain legal. I just like how the standard ones are more visible from the sides.
For the rear, I got the AdMore Lighting kit for the Givi E370 top case. The turn signals on it look cool IMHO - I need to get better video to post.
- dasshreddar
You would have to source the headlight from overseas(Thailand, power by pcx, Europe, etc...) and wire in the appropriate bulbs for the signals (the US ones might work?)WhiteNoise wrote:das, you got a link to share with 6footer for a "whole headlight" swap? Or a pic of one? Will it fit proper in both the 2011 And 2013 U.S. PCX? Or will there be modifying involved? Simples?
I'm just guessing that if I were to swap out the wink-e-dinks to a full face assembly the police here wouldn't even recognize/notice. Exterior to interior indicators? Nah. As long as I winked by law prior to lefty or righty turns I sense no problem. However, it still is a risk, you will be breaking the law in NYS. Lotsa folks don't even use their winkers on any vehicleThat IS So, So Wrong!!!
I personally think the stalks are safer, I sure notice other bikers signals with stalks more than those with the integrated ones.
The stalk versions are definitely superior.
Agree with das and gn2. Stalks better (I'll add, fugly though). Bit greedy, but Can ya do both without blowing up? Poof!
- 6ftMach1Girl
I don't see why not - especially if LED bulbs could be used. But then I am certainly not the electronics expert!!
- 6ftMach1Girl
Power by PCX website sells headlight block without lights:
Optics Original Honda PCX 901-33110-KWN
Sold without lights Front Full electric beam, light bulbs or
Fits Honda PCX 125 Version 1 and 2 and PCX 150cc
Focus depending on your country of residence,
headlight pods are not the same
control the reference of your original headlight.
Compatible with Optical Cable HONDA PCX 901-33150-KWN
I also looked at the wiring on same website - again it asks to specify model. I am going to try to email them to see if it is possible to have both.
