scooter trip to alabama
duallyman
Post by duallyman »
:D 1000 mile round trip on pcx to mobile alabama
back in february really windy temperatures in the 30s
Scootn@50
Re: scooter trip to alabama
Post by Scootn@50 »
Where did you ride from to Mobile? I live in Mobile. If you make that trip again hit me up. It's always fun to ride with others. :D
duallyman
Post by duallyman »
from jax fla ill be doing 3months tour starring in june 4 corners clockwise
so i will be going through mobile again
duallyman
Post by duallyman »
picture of scooterImage
duallyman
Post by duallyman »
duallyman
Post by duallyman »
fort pickens pensacola
duallyman
Post by duallyman »
willajabir
Post by willajabir »
Well, you aren't planning on washing clothes, never worry about fuel, and never be thirsty on that trip.
You got everything except Granny and her rocker.
I'm really looking forward to your report during your trip (and the pics).
Larry
2014 NSS300E born on 12/11/13
May the Forza be with you
I think that you will find the trip to be much more comfortable if you add a tall windscreen. You can always change it back out later, but for the trip you will find it to be more comfortable and fuel efficient, as well as making your ride less exhausting.
wei2go
Post by wei2go »
o_O Wow. Tell us more about your setup
duallyman wrote:Image
Nice setup. How did you get those Pelican cases mounted?
Do you have a ride report posted anywhere?
duallyman
Post by duallyman »
Behind the pelican case is rack made out of welded and mitred 1 inch square tubing with 4 holes for screwing the case to it in the front is1/8 inch thick 11/2 inch wide flat bar bolted to the frame under rear peg take out original bolt out replace with long one in back it hangs with 2 bolts on a pipe we'lded and
Bolted to bottom of top box rack
Detailed pictures of it is in ready for touring in general posted by my good friend driller
I don't have ride report yet I'm just figuring out the picture thing
Btw I like your dog
This thread: http://hondapcx.org/viewtopic.php?f=2&t=1603 -- very cool!
If you need help posting, a member posted a how-to upload pictures guide here: http://hondapcx.org/viewtopic.php?f=3&t=912 If you have trouble or need help, PM me.
Thanks, I like my dog too. :P
Good luck on your trip, you said you're starting the fourth -- less than week to go! :D
duallyman
Post by duallyman »
The other day I was resizing my picture on photobucket it worked on my laptop but today it's not working on ipad
duallyman
Post by duallyman »
Maddiedog I'm interested in how the big bore kit performs like top speed price and where you got it
The big bore kit performs well:
- Acceleration is ridiculously good compared to stock.
- Top speed with a new drive gear is about 5mph higher. The final drive gear makes the speedometer off, so I read top speed as around 65mph but am hitting just about 70mph actual.
- I still need more gearing, it has a lot of power at the top speed. I'm confident it will do 80mph, and cruise at 65mph, but won't know until I order another gearing kit.
- Way easier to maintain top speed, especially up hills.
- MPG drops to 75-85mpg depending on use. That lowers range a fair bit; I'm ALWAYS searching for a gas station.
I bought it from webike Japan, it cost around $500 including the camshaft (which I haven't installed yet).
I don't know if this is an adequate shot of the windscreen with the added piece on it, but it should give you an idea of its height. It works well. We decided to go ahead and get tall windscreens because I now have my own PCX 150 .
Us at Volgel Park.JPG (162.46 KiB) Viewed 3808 times
The nice thing about this is that the extra piece is removable because it is not bolted into the plastic but rather the clamps press rubber pieces against the windscreen on both sides.
