Givi Monokey Rack SR1123 installed
pawineguy
Total time spent was approx. 20 minutes - can't imagine it taking more than 30. Just waiting for the box to arrive now.
- Adapter attached and finished!
- photo5.jpg (69.45 KiB) Viewed 2787 times
- Base attached
- photo4.jpg (33.56 KiB) Viewed 2787 times
- Cover reattached
- photo3.jpg (34.8 KiB) Viewed 2787 times
- Drilled
- photo2.jpg (58.09 KiB) Viewed 2787 times
- Cover removed
- photo1.jpg (61.43 KiB) Viewed 2787 times
PAWineGuy
Eastern PA, United States
Forza 300 ABS 2014
Forza 300 ABS 2014
- willajabir
Re: Givi Monokey Rack SR1123 installed
I saved my cover instead of drilling holes in it. Not that noticeable once the box in on and you can take everything off and return to stock look if you want.
Larry
2014 NSS300E born on 12/11/13
May the Forza be with you
pawineguy
Totally agree. The black deck is very clean and if I had a do over I would probably go this route.willajabir wrote:I saved my cover instead of drilling holes in it. Not that noticeable once the box in on and you can take everything off and return to stock look if you want.
PAWineGuy
Forza 300 ABS 2014
Forza 300 ABS 2014
Looks nice and I'm glad to see that you don't need to drill holes to install the rack if you don't want to.pawineguy wrote:Totally agree. The black deck is very clean and if I had a do over I would probably go this route.willajabir wrote:I saved my cover instead of drilling holes in it. Not that noticeable once the box in on and you can take everything off and return to stock look if you want.
Can you tell me where you bought the rack and Givi Monokey case? And by Monokey does that mean you can adapt the lock to match your ignition key? thanks...
pawineguy
Mono key means the supplied key locks it to the rack and locks it shut. The rack was purchased from tourandride and the case came from revzilla. Pics of the case tomorrow when it arrives.rew750 wrote:Looks nice and I'm glad to see that you don't need to drill holes to install the rack if you don't want to.pawineguy wrote:Totally agree. The black deck is very clean and if I had a do over I would probably go this route.willajabir wrote:I saved my cover instead of drilling holes in it. Not that noticeable once the box in on and you can take everything off and return to stock look if you want.
PAWineGuy
Forza 300 ABS 2014
Forza 300 ABS 2014
- skuuter
Looks NICE.....I usually go the GIVI Route, but opted for the Honda Rack and Case for the FORZA....I bought (2) FORZAS at the same time, so my Dealer gave me a Great Package Deal on Genuine Honda Accessories.....
Totally agree. The black deck is very clean and if I had a do over I would probably go this route.[/quote]
Can you tell me where you bought the rack and Givi Monokey case? And by Monokey does that mean you can adapt the lock to match your ignition key? thanks...[/quote]
Mono key means the supplied key locks it to the rack and locks it shut. The rack was purchased from tourandride and the case came from revzilla. Pics of the case tomorrow when it arrives.[/quote]
Do mind you revealing what you spend for both? My wife wants one on her new Forza the Honda ones are very expensive as I think I was quoted $350-$400 for the case and rack.
pawineguy
Looks nice and I'm glad to see that you don't need to drill holes to install the rack if you don't want to.rew750 wrote:Totally agree. The black deck is very clean and if I had a do over I would probably go this route.
Do mind you revealing what you spend for both? My wife wants one on her new Forza the Honda ones are very expensive as I think I was quoted $350-$400 for the case and rack.[/quote]
For both items it was around $450 - I would take a look at giviusa.com, and also some of the videos on revzilla comparing the different cases - I chose an expensive case from the more expensive monokey line, because I wanted to be able to carry extra weight - if your wife is happy in the 6 to 7 pound capacity range then the monolock series is much less expensive.
PAWineGuy
Forza 300 ABS 2014
Forza 300 ABS 2014
